Woodturning diary? *LINK*
Robert D. Macgregor
>As a beginner (and only occasional) turner I've always been a bit embarassed about the inadequacies of my mono-tube lathe (and, of course, covetted something bigger and better!). Today I stumbled on this site and couldn't believe the effort this guy, presumably on a low budget, put into his monotube; I was really impressed with his inventiveness. See if you agree.
BOB
Wood turning (Lathe & Tool)
Re: Woodturning diary? *LINK*
ben d.
>Can you believe.///::
He should have made the lathe from scratch judging from the tools he had use of to make all the attachments.
Some thinker
Carol from AZ
>That guy is incredible! It takes a while to go through the woodturning topic but it is fascinating! I bookmarked his home page. When I have more time I will explore more. His mind is to be admired!
Russ Fairfield
>Not necessarily a low budget with all of the metal machining he has done. That takes either a home shop with machining capability, or access to one. Unfortunately, after all of these modifications and additions, he still has a mono-tube lathe with all of its limitations.
Robert D. Macgregor
>As I went through his progressively more complicated modifications and additions, I expected to see him replace the tube with rails next!!
BOB
Roger in MO
My thought exactly NM
Roger in MO
Great link! -- Thanks --
Chuck Engstrom
dwr
>Sweet!
Given his space constraints, he has made great use of the mono-tube. I picked up a couple of tips he used/made that I can incorporate into two of my lathe set-ups.
Nice to see that even the Japanese scrounge parts and enlist help from friends. However, given the CAD drawings he made, I think he has a lot of skills that go unmentioned;)
He seems to have progressed in his turning skills quite rapidly. Should be an encouragement to every turner!
Thanks!!
