hollowing rigs - different application
Carol from AZ
>And a gloat. Today I met a guy who offered to let me use his lathe! There are few 'issues.'
But I think the collective wisdom on this board can help me out. His lathe is a Delta something, he thinks. Old, he said. Has, maybe, if he remembers right, a 'tail stock problem.'
He cannot use it as is, not because it needs work, but because he only has the use of one hand and arm - his right.
Could a hollowing rig to manage the cutter allow him to use his lathe?
If so, will you all help me with details, dimensions, pictures, a zillion questions, etc? I am a pretty good jig builder for flat work, but I don't yet understand the dynamics here.
One last thing, he has a friend who is a retired machinist and he knows where to find a welder.
So if I help him find a way to use his lathe himself, I get to use it as well. In all honesty, he will probably let me use it anyway, but the spirit of turners is to help one another. If I am to be a turner, then I will embrace the same spirit.
Re: hollowing rigs - different application
tm
>"He cannot use it as is, not because it needs work, but because he only has the use of one hand and arm - his right.
Could a hollowing rig to manage the cutter allow him to use his lathe?"
I'm using an OB O'Brian hollowing rig with IMPAIRED function in both hands. Everybody functions at different levels,
so really theres not a lot I can tell you with certainty.
The hollowing rig allows me to work the insides of vessels pretty
easily and with my hand function ( no grip ) allows me to turn
pieces I'm happy enough with to sell and give as gifts.
I would be concerned about safe roughing turning of blanks and outside work on the toolrest with the the use of only one hand.
Bandsawn, rounded blanks would be a huge advantage. I strongly
suspect that some determined turner out there is doing or has done it.
I had the advantage of experience turning prior to injury
and waited for way too many years before trying.
( read huge regret here ) I convinced myself wrongly that turning
could only be done safely in one particular way and having a deathgrip on a tool handle was essential.
In the beginning a catch would send my tool flying and scare the
hell (sorry Rev. Doug ;) but its true) out of me. I started reading eveything I could get my hands
on here on the internet and watching instructional videos and soon I found I was gaining more tool control. I still consider myself a novice after about 2 years of this style of turning but I would never
give it up. If your friend has the desire, $$, and some mechanical know how there are probably ways to adapt the lathe for his needs.
I am sure others here can help with ideas.
You can contact me here or send me an email if you have questions.
John
Re: One armed.... hmmmm. (Long)
Allen Neighbors
>Carol, what a noble thing to do! Just attempting this is really something!
If you've done woodwork before, you can build a hollowing rig. It's not wood, but the dexterity is the necessary thing. Let me know... I can take some better, closer, pics of my rig and email them to you; and I'm sure there are some photo tutorials around somewhere.
However:
I don't know how a person with only one arm would be able to get a piece ready for a hollowing rig. I would think it well nigh impossible, but I've been surprised before.
Getting the blank ready would be hard to do, unless he bought some ready made blanks... or you might fix him up with some. :o)
Mounting a blank between centers would be difficult, but he could use a faceplate, but then he would need a way to lock the spindle while mounting the face plate. (A faceplate would require either a glue block for the screws to go into, or a longer blank than normal.)
Holding the tool while roughing and shaping the blank... I don't know how that could be done. Maybe a brace of some sort could be used, but I don't know how. He'd need to hold the tool down on the toolrest, and guide the toolbit, and hold the handle... normally requires two hands.
Reversing the shaped blank into a chuck for hollowing could be done... difficult, again. Is he agile enough to get a foot up on the bed to help hold a piece in a chuck?
Pre-boring a start hole could be done. Then mounting the hollowing rig would be the next step.
Then the hollowing. Changing tool bars, changing tool bits, sharpening... All these steps would normally require both hands, but could be accomplished.
He could have a parting-off box so the piece wouldn't go bouncing around the shop.
Is he up for one of the greatest challenges of his life? Are you?
It could be done... but with great difficulty... Let's see what others have to say.
tm
>"Holding the tool while roughing and shaping the blank... I don't know how that could be done. Maybe a brace of some sort could be used, but I don't know how. He'd need to hold the tool down on the toolrest, and guide the toolbit, and hold the handle... normally requires two hands"
I was out right now staring at my machine and thinking about what Allen says above...
Maybe something along the lines of a bit holder and adjustments
like on a metal lathe. A "captured" tool bit and little wheels
that would adjust depth, height, bevel angle ....
Seems like somewhere I read about a guy using or thinking about using
a metal lathe for spinning wood.
tm
Carol from AZ
>Thanks, I like your attitude as well.
Bill has two arms and hands. He just cannot use his left arm and hand. As for getting a blank ready and mounted, his son can help him with that.
I just wanted to know if a captured system, maybe even incorporating an arm brace somehow would allow him to turn the outside and inside of a bowl.
I went through the articles and found Al Crandall's rig. I'll have to study the article and pictures. What about your rig would you change if you built another?
If I have to make two of them to it right for him, I can always send the spare to Carole Valentine!
Ray Thompson - Middletown,IN
>At first glance I don't see any reason why a one armed person couldn't turn. My initial thinking is to make a special handle that attaches to the elbow stabilizing the end and freeing the hand to guide the tool tip. Think outside the box, just because a lathe tool handle looks like a lead pipe doesn't mean it has to.
Ray
Carole Valentine
>Huh? How did I get into this? LOL! I was just reading the messages and trying to think "How would I handle it safely if I could only use one hand?" I don't know the answer, but usually where there is a will there is a way. Does he have any use at all of his other hand and/or arm? One thing to remember is that much of turning is more body movement than hand movement. At least it is for me.
I have made one
Phil Joines Krum, TX
>For LOML. She has arthritis in both hands and can�t use a gouge for more than 20 minutes a day.
The key idea is to make, in addition to the normal cutters in a captive system, a second set designed to cut on the outside.
There are a lot of captive system designs available. The one I like after having made about 20 of them is first, is a handle about 16� long made from 1� x 2� rectangular steel tube. One end has a 6� length of 5/8� cold rolled steel welded to it. Hers is filled with lead shot to reduce vibration and it's heavy. A set screw type motor shaft connector is used to connect the cutter bars to the handle. The rear support consists of a banjo whose hole matches the stock banjo and a capture rest made from 1� square tube 48� long. The post for the rest is welded 14� from one end of the bottom tube. It needs to be long enough so the hollowing tool rests level and with the cutting tip on or slightly below center. The second tube is attached using threaded rod so the handle is a sliding fit between it and the lower tube. Wax the inner surfaces of the tubes and the handle.
For a full set of cutters I�d make at least 7. The overhang of a 5/8� bar is limited to about 10-12� before vibration becomes a problem so the over all bar lengths are about 14�. The first has the cutter sticking strait out. The next two have the cutters at 45 degrees, one to cut on the inside like a regular hollower the second cuts on the outside. Make tow with the cutters at 90 degrees, again for inside and out.
The next two are more complicated. On the inside bar the curve is to get inside the top surface. The degree of bend and it�s length will determine how flat and wide the top surface can be. The outside bar is to cut the side of the bowl or hollow form when the top is facing the tailstock. The cutter needs to be able to bend around the top. Again, the shape will depend on the shapes he wants to make.
The best way to determine the bent shapes is to draw full size the desired shapes and the positions the cutters need to reach to make them. Considering the amount of cutter bar overhang doing the outside a larger diameter bar may be needed to prevent vibration.
All of my cutters are �� diameter metal cutting bits. There are several types available, HSS, Cobalt, TIN, Etc. They all work about the same. I usually make so the tips protrude about 1� from the bars.
A laser isn't needed to turn bowls but isn't hard to make or mount. We can get into them latter if you want.
I can send you some pics if you decide to go this way.
Re: One armed.... hmmmm. (Long) *LINK*
Stan Townsend
>Carol I sold a hollowing rig to a stroke victim with a paralyzed right arm and he could raise it and place it on the tool and let it serve as an anchor. He guided the tool with his left hand. It will serve for hollowing and outside turning as well. Take a look on my web site.
http://www.elbotool.com
Jim Swank
>I was about to suggest a look at the elbo-tool or similar. Based on the demo I saw at Louisville, it should be quite usable with one hand, and perhaps adaptable for turning the outside of small forms and bowls as well.
You'll want to fix any tailstock problems first, I think, since the tailstock can serve as an extra hand for many operations. A small hoist over the lathe can be used to hold a blank in position, the tailstock brought up and used to secure orientation to hold a piece for chucking or faceplate mounting. Rather than parting off, the old trick of a waste block glued to the piece with a layer of paper between can be used.
Riding the bevel allows using a gouge one-handed, at least on a ressonably well rounded blank. Obtaining the muscle memory (training) to accomplish that may be problematic. It seems reasonable that a captive rest like that for a boring bar could be used to help constrain the gouge.
Focus on what your friend can do. Stability and control of the rest of his body will determine what is possible far more than a paralysed left arm.
don lewonczyk
>Carol, you suggested that you you would be interested in using the lathe somewhere along the line so maybe between the two of you it will happen. You turn the outside your friend turn the inside and with all the helpful info from the experts you already got you'll be on your way. Later as he is more comfortable with the inside turning you may in your research find the right rig for him for the outside. Hope it helps. don
One arm turner,
Jorge Castaneda
>Carol,
In the Maine Woodturners group. there is a one arm turner, forgot which arm and forgot his name, but he turns, does everything whith his one arm.
Where there is a will, there is a way.
Encourage him to experiment.
Jorge
Re: ????
Carol from AZ
>Gotcha, didn't I? I remember your Christmas wish for a hollowing rig from a few days ago. :)
But you did get me to thinking about how he handles his body. I have never asked him how he came to lose the functions hehas lost, but head scares suggest some severe head trauma. He drags his left foot as well when he walks. His balance seems to be precarious. At least it is to me, but then who am I to say? He IS building a canoe, so he seems to more capable than one might think. I have helped with some angle cuts he thought too dangerous for him to attempt.
Keep the thoughts coming. It would really be cool to see him accomplish this.
Re: I have made one
Carol from AZ
>Thanks, Phil. I had also been thinking about cutters, but again a am very, very new at turning and I don't understand all the dynamics that come into play.
I copied the text of your message for later consultation. Pictures would be great!
Carol from AZ
>Thanks, Stan. I've bookmarked your site. Does your rig attach to the tailstock in some fashion?
Carol from AZ
>That too was my thinking, Ray. Something like the cupped end of a crutch that cradles the forearm near the elbow attached to a captive tool. That way, with the proper set of cutters, he could use that hand and arm to guilde the cutter. When I get over there, I'll take my camera, try to determine what the deal is the tailstock, and talk more with him about his physical capabilities as applied to turning.
Wish I had about 20 years experience here, so I could understand the dynamics - body position, arm/hand position, range of necessary movement, etc. I feel like the blind leading the maimed. I really appreciate you guys and gals helping out. Keep the ideas coming. I am logging them into a file, so Bill and I can figure out what might work best for him.
Re: Carol-the old saying about.....
Jamie Donaldson
>... where there's a will............... I have had students in both photography and turning with one arm. The outsige turning can be accomplished with an armbrace holder like the Stewart/Sorby which will allow the use of bowl and spindle gouges with ease. The hollowing can be accomplished in a similar manner, but a captured bar system is easier to handle and learn.
Re: One arm turner, go to site *LINK*
Ruth Niles
>Carol,
Here's the site of a turner with one arm.
Also try the Maine woodturners site that Jorge suggested, there may be contact info and you could get info from direct.
Good luck
http://chippypah-workshop.co.uk//index.php
OB O'Brien
>Carol, as you know I have made many captured hollowing rigs. One of my customers has found that she can turn bowls, inside and out with one of the cutters in the hollowing rig. She also uses it to do the standard hollow forms. Tm has one of my rigs that Allen Neighbors modified for him.
I'm going out to the shop in a few minutes and try something. I have an idea and I think there is a way to modify my hollowing rig so it can be used with one arm. I will get back to you all, this afternoon. In the meantime find out what kind of lathe he has and what the swing is and what diameter the tool rest post is. OK?
Cya OB
>I doubt that I can find it but I'll look tonight. There was an article about a 1 arm turner in one of the magazines( I get like 12 or 13 which makes it tough to find sometimes). As I remember that person didn't use any unusual tools at all.
My experience with the boring bar is that you can take really small controlled cuts with little effort. I think this could be done just as easily on the outside of a vessel, even a rough one with relative safety as long as you approach the wood slowly.
Re: I have made one
>Here's one set up that I made for a club member. This one uses 1" diameter cutter bars for deep hollowing. Notice the red engine hoist in the back ground.
If you send me your address I can send you a CD with detail pics. My dial up connection is to sloooow to email them.
Ric Taylor
IIt Can Be Done
Ric Taylor
>Carol,
I have a friend with only one hand who is an excellent turner. I have not seen him use a hollowing rig. He uses the same scews and gouges and hand-held hollowing tools that everyone else uses. His work is beautiful and is on display in galleries.
Good luck,
Ric
Re: I have made one
>Here's a convential D handle system for 5/8" bars. I like the rectangular tube handle better, it's more manuverable. This one is just for inside work. He'd need a second set of cutter bars for the outside.
Stan Townsend
>Carol, In answer to your question, Yes, It clamps to the Quill and is very sturdy. Once clamped and the tool rest set at center it can be operated with one hand. It can reach outside and inside. The end cutter will adjust to about 270 degrees and can be extended or retracted with one hand.
Re: I have made one
>The rear tool support is shorter than we use. Our lathes aren't against the wall so there is more room for it to stick out the back. A longer rear rest allows more manuvering with out needing to move the rest.
