I need to hear experiences with
Bart Leetch
>Over the head & face battery powered filtered fresh air systems. Things like how well they seal quality of filtration & battery longevity & anything else you may have experienced with these systems.
Bart Leetch
Re: I need to hear experiences with
Ed Karch
>Have one of each and prefer the Trend. less stuff hanging down. seal is not a problem with either type as it is a positive air flow and is always exausting until you shut it off at which point it starts to heat and fog.
tm
>Taking care or your lungs is money well spent.
In the long run it buys one more quality time at the toolrest.
I'm a trendie, it works well. I keep an alternate battery on the charger in case the one in use quits.
When the battery quits you will know because it does heat up inside.
If you are in a noisy shop you can wear ear plugs
or the muff type of hearing protection.
I'm short so I wear a cap underneath the headband assembly to keep wood shavings & dust out of what hair I have left.
I used a cartridge type dust mask before...
theres no going back.
tm
T Daniel
>Bart, I wore out 2 of the 3M Raccal hoods before going to a non-powered Trend Ace. The Raccal hoods were better than nothing but I had 2 problems with them. In a cold shop they blow cold air down on your head and this was a problem for me. Also, the plastic hood faceshield was hard to keep clean. I went to the Trend Ace because it filters to the same level as their powered mask but there is no battery or plastic faceshield to fool with. It works well and it is a lot cheaper.
TD
Bill Blasic
>Ed,
FYI if you are interested in the Triton a few of us in my group just purchased the Triton from Amazon.com. They have it for $189.95 and if you by it before Oct 31 you get $25 off and free shipping. The total was $164.95. I have not tried it myself as it is a Christmas present. Others have got it and tried it and they like it.
Bill
Bill Blasic
>Bart,
Sorry read my note under Ed, sorry Ed
Bill
Air ace- where to buy?
david
>Hi Terry: I see that the Trend Air Ace is a UK product. Are they available for purchase in the states? I take it that you are not fond of the optional face shield. TIA, David
Stone Mountain Power Tools
T Daniel
>is where I got mine. They were sharing a booth with Trend at the Atlanta Woodworking Show. I was told that Highland hardware would also be stocking it but I have not checked to see if that ever happened. You might email Trend in the UK and ask for a local source of their product.
