Vacuum Pump Help Please
Cyril Griesbach
>Several months ago I bought a Gast vacuum pump from the Surplus Center and a Oneway vacuum adapter for my PM3520B. Well, this afternoon I finally got around to begin setting some things up and I wired a cord and plug for the 220v outlet and removed the lathe hand wheel and put on the adapter.
Pump ran just fine, hose hooked from the inlet side of the pump to the adapter and pulled some vacuum. BUT there is not enough vacuum to hold anything. I put my hand on the spindle end (carefully because I didn't want to get stuck) and there isn't enough holding power for anything at all.
Checked as best I could for leaks (made some smoke), covered the spindle opening and couldn't find any. It wouldn't even pull any smoke into the spindle.
I know this isn't a complete setup yet but shouldn't it pull something tight to the spindle end.
Need some help here and offering my appreciation in advance.
__________________
Cyril
Re: Vacuum Pump Help Please
david
>Cyrl:
You did not mention what kind of adapter you are using. I had the hardest time getting the "factory" adapter to work on my Nova 3000 until I scrapped it and got the EZ vacuum unit that uses a bearing and a table lamp threaded rod to conduct the vacuum through the headstock area. I am not familiar with the Powermatic--perhaps the air leakage is within the headstock area. The EZ vacuum adapter was easily moved over to my Vicmarc VL300 which replaced the Nova.
Cyril Griesbach
>David,
The adapter is a Oneway and as the Powermatic does not have threads on the outboard end of the spindle it is a pressed fit with an O ring. I tried the O ring both between the spindle and the adapter and between the adapter and the insert. Not sure which is the right way as the usual Oneway instruction are...in this case...non existent.
Cyril
Russ Babbitt Jr.
>I'm not familiar with the Oneway adapter. Do you have a vacuum gauge? If so disconnet all your plumbing and just screw in the gauge. This will show if the pump is pulling vacuum and how much. A friend just received a pump from your same source and had to send it back. It was only pulling about 15 in. The second one was not much better. Took it apart and freed up a stuck vane and now gets 25. I would have liked to see more but he is satisfied.
Tony Reynolds somewhere near Newark, Ohio
>The o-ring goes between the spindle and the adapter to make the seal at the spindle end. I have the Oneway on my 3520a and it works great.
Tony
Bob Fawcett
>Cyril,
A vacuum chuck gets its hold from atmospheric pressure. This is about 15psi at sea level. The hole in the spindle is about 1/2" diameter. Thats less then 1/4 square inch area. You'll only get 3 pounds from that.
If you use a 4" diameter chuck you have over 12 square inches area and about 180lbs holding force.
When you put your finger over the end, does it leave a circular impression when you take it off? Can you hear the vacuum pump pitch change?
If so its probably working fine.
Cyril Griesbach
>Tony, thanks for the info on the O ring. I'm assuming you mean between the spindle and the insert. That's where I also thought it should go for the reason you state.
Bob, yes it did leave a slight mark on my hand when I removed it but I can't remember if the sound changed pitch. I'll have to check it again. I will get a gauge, which I'll need anyway, and do some more diagnostics. However, I'm leaving town soon for about 11 days. I'll try to follow up on any further suggestions even though I won't be able to post.
Thanks for the help,
Cyril
