First Hollowing Rig, Pic 1
Allen Neighbors
>This was caused by that Red Elm. :o) I'd been planning on trying to build a deep hollowing rig for some time, but I had so much trouble with that Red Elm piece, I decided that it was now time.
This is made from 1" square tubing, and 1/2" allthread. I didn't do the welding.
I didn't make a block for between the ways, choosing instead to make a clamping device that goes across/under both sides of the Oneway ways.
This pic, taken before I installed the set screws, shows a 3/4" boring bar in the business end.
Re: First Hollowing Rig, Pic 1
Allen Neighbors
>This shot shows the Don Pencil curved tool mounted in the business end of it.
Jim Shaver Oakville, Ont.(remote in Minneapolis)
>Very Cool shots!
I always get the feeling like I am at the dentist's office when I see these rigs set up.....don't know why?
Take care,
Jim
Re: First Hollowing Rig, Pic 3
Allen Neighbors
>Sorry, previous pic was #2. (Couldn't edit it.)
This is a pic of the 3/8 x 16tpi set screws that I put in it. I may have to have some 3/8 nuts welded onto the holes, but for now I think this will suffice.
I intend to put a laser mount on it at a later date, but I haven't yet decided which of three ways to mount it. I haven't used this yet, so I'm not sure how much vibration there is with it. None, I hope. I'll put some of the slick nylon stuff in the track someday, too.
It was surprisingly easy to build this rig. For anyone with even a tiny bit of mechanical ability, it would be an enhancement to your tool collection. :o)
Re: Thanks Jim,
Allen Neighbors
>I had to get my step stool out to get high enough to take these.
I hope your dentist's office didn't look as messy as my shop. :o)Speaking of dentists... I'm looking for a good dental light... maybe one day I'll luck into one.
Thanks for looking.
Ed Karch
>You is one talented dude. Nice rig.
Carole Valentine
>If I could weld, looks like I could build one of those! Unfortunately I can't weld (don't have the equipment and don't know how.) Looks like a nice job Allen. Let us know how it performs.
Lan Brady
>Allen,
This looks fantastic.
Is it better to have the cutting tool on the left side or the right?
I don't know.
Lan
Leo Van Der Loo
OK the shop looks used, but that unused look
Leo Van Der Loo
>of that lathe still bothers me Allen :-)))
Looks like a sturdy setup Allen, maybe one of those days when I can/want build instead of turn, I'll make one like this, KISS is the way I like it too.
Have fun and take care
Leo Van Der Loo
Re:It looks very servicable Allan, so ...
JamieDonaldson
>... get busy and put it to the test! Lube the tubes with candle wax until you fit the slicky nylon- I would like to find a reasonably priced source if you can supply one.
Allen Neighbors
>Thanks, Carole. I can't weld, either. I had the tool arm made to size... 5" X 24". Then I just used a hacksaw, drill, and grinder. Then I used my sander to smooth the parts that move against each other. It's really easy. If it rattles or is a little too noisy, (being hollow itself,) I'm going to shoot some expanding foam inside the tubes. ('cept one, of course) :o)
Allen Neighbors
>I've never used one before, so I don't know either, Lan, but I figured that I would be closer to the tool with it on this side. If I'm wrong, I'll just turn it over, and then have to do the set screws on the bottom.
thanks for looking, :o)
Allen
Allen Neighbors
>I'd say 'fortunate'... thanks Ed.
eliot d
>Nice rig! When it comes time for you to set up a laser, I can't recommend highly enough the X/Y control that Don Derry sells. It just can't be beat.
Re: If it was black or green, or
Allen Neighbors
>any color but white, I probably wouldn't wipe it down as much Leo. :o)
I want to turn all the time, but when I get started, I discover another tool I need to help me do it more efficiently. This one was definately simple.
Allen Neighbors
>Eliot, thanks. Can you elaborate a little more on the X/Y?
Allen Neighbors
>Can't wait to get it going! Candle wax... sounds good to me... I had been thinking paraffin...
Jamie, I saw those slick nylon strips advertised in a catalog, but can't remember which. I'll see if I can find it. They will really help, I believe.
Lee Valley has the slick stuff
Carole Valentine
gil jones
>Really fine jog building that hollowing rig!!!
Torque arrestor
Jorge Castaneda
>Allen,
good work, to my mind the torque arrestor would be more efficient if the bar is located on the side near you, in the pic is on the far side, Just flip it
Jorge
nit picking in Stonington
Yes, you can Carole!
Jorge Castaneda
>the tubes are hollow, all you have to do is put some strong wood inside and drill holes and shoot screws, the hardest part (for me) would be finding the tubes. Of course some joinery will be needed, but hey! we were flat workers didn't we?
Bob Fawcett
>Fine looking rig Allen.
Mike Hamilton
>Al Crandall has a no-weld hollowing rig in the articles section.
Regards,
Mike Hamilton
Plainfield, IN
>Good looking rig. I have been thinking of making one.
It seems to me you have the restraining bar on the correct side. I don't have one and have never uses one, but it seems to me that if the bar is on the far side, the shaft of the tool will just rotate while the force on the tip tries to lift the restraining bar. If you turn it over it seems it will try to lift the tool. Try it both ways and let us know.
The two nuts between the bars was a good idea, but couldn't you have made a spacer out of a short piece of the same tubing with a hole through it and a washer to create a little extra space?
Not sure, but I think you are going to want to make the restraining rig asymmetrical. The bars perpendicular to the bed want to be mostly on the far side I think, but I am not sure. Now that I think about it, when inserting the tool through the hole in the vessel, you may need to swing the handle toward you to get the tip through the opening if it is small. Let us know on that too.
Is that the square tube from Lowes?
I think the slick HDPE tape might be excellent. Either on the top and bottom of the D handle itself or on both sides of the straining bars or both. If it will stay in place, it might reduce the rattle factor in addition to being slick.
eliot d
>Allen. sure. Don Derry sells a complete hollowing rig with a superb adjustment mechanism for the laser. But he also sells the laser adjustment separately for $100. I know that sounds a bit high, but trust me it's the best out there. ALL the others I've tried (granted I haven't tried them all) are fairly simple setups that simply allow you to slide or pivot the laser in a couple of directions. But what always happens is that as soon as you turn the wing nut or whatever to lock it in place, it moves a bit and the laser dot is not where you want it. So you have to keep fiddling around until you get it right. The Derry has some kind of " non- lash back threads " -- or something; you can't see it because it's inside the mechanism, but as you turn the screw mechanism to move the laser ,it stays absolutely put --it's doesn't spring back even a fraction of an inch. When you look it, it just looks like two brass square cross section "tubes" that are at right angles to each other with a wing nut to adjust each -- one in the X direction, and the other in the Y direction at right angles to the x direction. I think the laser comes with it, too. It turns on and off by just twisting it about its own long axis.
