Turning a Lamp Post
Turning a Lamp Post
Turning a Lamp Post
Sean Troy
>Hello all, I'm want to try and turn a lamp Post for our back patio to replace the old wood one there now. What is the best wood to use? I will be turning it in two sections.How do I go about running a hole for the wire up through the center? Thank you, Sean
Re: Turning a Lamp Post
Stuart Johnson
>Have you thought about staves? This would give you a hollow post and eliminate the possible cracking. I think White Oak is suppose to weather well if treated properly.
Sean Troy
>I don't have the saws to cut them.
>Turning a lamp post in two or three pieces is certainly possible and if you make the joints at the right places, no one will know it was joined.
I might glue up the post with a hole already in the center for the wire. It is easier to obtain material in one or two inch thickness that in four or six. It might be easier to rout of leave a hole than to drill one later. I would use waterproof glue such as Gorilla Glue or Epoxy or one of the waterproof PVA types.
Either leave "dowels" on one end of each piece and use a matching bit to drill holes in the ends of the other piece to allow you to join then or, you could leave a channel up the center that is an inch and a half square and then glue a 2 x 2 in the ends after they are turned to serve as "loose tenons". Drill a hole through them for the wire.
You can use any of the naturally decay resistant woods, Redwood, Heart pine, Osage orange, black locust, walnut, etc. This will make it clear to you why the original post was made of something that rotted. Another choice would be to soak the post in a preservative, but use lesser wood. Also, examine the post you have now and if it, like many, rotted at the bottom you could make that section of decay resistant wood and soak the rest in preservative. IF the post is to be painted, you should prime and pant the sections before you assemble to be sure all the end grain and other surfaces are sealed as well as possible.
Re: Turning a Lamp Post *LINK*
Chuck Engstrom
>Hi Sean -- let me suggest that you look at www.brucepostco.com (link below). This is a very small local outfit for whom I do some work. He has a device which bores a hole straight through a post blank up to 14 feet long -- quite a gadget. You might be able to make a deal with him for a drilled blank not yet turned. He works almost exclusively with redwood and cedar for exterior use. For that matter, you may find one of his stock items to be to your liking.
As I say, I do work turning for Bruce sometimes so there is a business connection here, but I wouldn't expect to benefit from this suggestion if you are going to do the turning. You could certainly tell him I suggested you call him.
Best--
Chuck Engstrom
Chestertown MD
http://www.brucepostco.com/
Ron McKinley
>I've made a few in two pieces by turning tenons to fit into holes drilled to match. To get the wire through use a lamp auger like this one: http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=036-0574 It goes through the tailstock to drill the hole for the wire.
I've also laminated pieces that I have routed a trough through for the wire before glue-up. Then carve little blocks to fit into the holes on each end so you can mount and center it on the lathe. .......Ron
Elevate the Lamp Post
david
>--with a curb, base, or pedestal that will keep the wood out of the water when it rains. Contact with the ground or slab where moisture accumulates is a good recipe for wood rot.
