parting tool
parting tool
parting tool
>Since my favorite parting tool (an offbrand 1/4" diamond tool) came up missing after my spring fling turning day, it's time to by another parting tool. I thought I would throw this out and find out what is your favorite parting tool and where is the best place to get it. I'm also interested in the ones that have a small flute. If you have one of those how do you like it? Which way do you sharpen it.
Right now I have an old 1/4" flat sided high carbon steel tool. A 3/16 diamond shaped Sears Craftsman high carbon tool. Two homemade thin parting tools, one made from an industrial hacksaw blade and one made from a keyhole saw blade.
Re: parting tool
Re: me too
Allen Neighbors
>John, thanks for posting this. I, too, have an old Sears high carbon parting tool, and am in the market for a really nice one. I'll be watching this thread! :o)
Re: parting tool
Re: parting tool with flute
Ruth Niles
>John, I have the parting tool with the little flute and I'd like to know how to sharpen it, too! : ) It tends to confuse me because you put the fluted side of the tool on the tool rest. Just feels backwards to me.........watch I'm going to be informed I'm using it upside down!
It does part off very nicely and I use it on small bowls to cut a very tiny foot, works great for that.
Re: parting tool
>Anyone know what Nick Cook uses to cut the notches on his Honey Dippers. I remember him saying he experimented with parting tools until he found one that cuts really clean.
I also have one of the Oland parting tools. The one that uses the metal cutting parting tool blade. It cuts really nice but I don't feel like adjusting it in and out for different cutting tasks so I tend to not use it.
Re: parting tool
The best parting tool
Bill Stehman
>Ruth,
You have the sorby fluted parting tool. The plastic guard that came with it goes over the flute and down. This prevents chewing up your tool rest. Simply turn it upside down and grind away to sharpen it.
The best parting tool I have found was in the kitchen drawer. An old Japanese stainless steel carving knife with the sharpe edge honed flat ( so we don't cut ourselves)then grind like any other parting tool but with just a slight bottom grind like Ellsworth does. The original knife grind gives you a diamond shaped parting tool that is extra long and thin but works better than anything I have ever purchased.
Re: parting tool
David
>I attended a Ray Key demo at Provo last year where he did his characteristic pagoda boxes. He said the parting tool he recommended was this thin one with a flute. The tool was about 1/8" thick, but a couple or three inches from the tip, it narrows down to about
1/16" in thickness. The tool has a single bevel with the flute on the side of the long end of the bevel and is supposed to be used with the side with the long end on the tool rest. The flute is only at the part where it narrows down. After the demo I saw unhandled ones for sale at the parking lot event they have at Provo, and bought one. I believe it is made by Ashley Iles and is from high speed steel. It is sharpened by placing the bevel flat on the grinder, but haven't had to sharpen it yet--perhaps because I don't use it too often, and is a testament to a good design.
Re: parting tool
Re: parting tool
Phil Joines Krum, Tx
>John,
Being a woodturner I of course have 7 or 8 parting tools :>). For general use I like the 1/4" diamond Artisian from CS. For narrow cuts are 1/16" Cris Stot style, two of mine were made from a power hacksaw blade and work as will as the comercial one. For small turnings I use the fluted 1/8" wide. (ground with the flute up, on the flat side) I have made one of those too from a dull planer blade using a air cutoff tool with 4" abrasive wheels to cut the flute. Then there is the bedan for spindle turning and a 1/2" square made from a metal cutting bit with one bevel ground to about 35 degrees. I also have a Delta 1/4" wide flat blade that is almost never used.
Re: parting tool
Plastic guard?
Ruth Niles
>wow, my tool came with a plastic guard? Wish you had told me that when I got it 2 yrs. ago!
Re: parting tool
Re: parting tool
Ken Grunke from SW WI
>I have one made from a HSS planer blade, 1/8" thick that is used the most. Instead of a diamond profile, it's flat on one side and curved on the other. I've been using this for years and like it much better than the angled sides of the diamond. It's great for angled parting cuts, such as parting the bottom of a goblet. I made a split collet handle for it which is hollow so I can adjust the blade in or out.
The other parting tool, on the left, is made from an industrial hacksaw blade, 1/16" thick with the same curved profile.
Re: parting tool
Re: parting tool
Mkauder, Phenix City, AL
>John,
Like Phil, being a tool nut, I have 4-5 parting tools. I have a 1/4" square Taylor, I only use it mostly line a Bedan, or for square shouldered cuts. I have a traditional Diamond Taylor, that I don't much like for anything - so I ground it to cut cones like Stephen Glasner's does - I still dont like it. I have the smaller of the two Sorby parting tools with the groove in it. That is a great tool, it cut pretty fast and cleanly. HOWEVER, the one I like the most, is one that I made from a good carbon steel 1.5" wide carving knife. I took the wooden handle off, and epoxied the tang into a 15" handle. I ground it with wide part of the blade at the top, ground like the Ellisworth parting tool on the top, but the bottom ground straight at about a 45 degree angle.
I use the homemade one for anything under about 3" in diameter - nice clean narrow cut.
Mark
Re: parting tool
Mike Stafford
Re: parting tool
Mike Stafford
>I have several parting tools. My favorite for parting boxes is the Sorby 1/16" fluted which cuts very cleanly and removes very little wood helping ensure a grain match at the box join. For general parting duties the Sorby 3/16" fluted is my choice. The fluted spurs are on the bottom of a long taper and the tool itself is narrower at the top than at the bottom where the spurs created by the flute is. Makes for little or no binding in the cut. For square spigots and general work I use a generic 3/16" diamond pattern. I have a stack of the Craftsman diamond parting tools that I bought when a store did a close out on its turning tools. I still pull the little Craftsman 1/8" diamond when I am doing certain operations...
Re: parting tool
Re: parting tool
Lan Brady
>John,
Many options. The only one I can add, is for small items. I bought a paring knife at Dollar tree. It is 1/32" thick. Several advantages. It already has a handle and once you grind the point, it cuts so cleanly that you can start sanding with 320 paper.
One limitation- a 2 inch diameter piece is about all you can cut through.
Good Luck in your search, Lan
Re: parting tool
Re: parting tool, Ken........
Ruth Niles
>I really like that parting tool from the planer blade. I have a 6" jointer/planer (antique Euro) and have a lot of extra blades, can I use them? Any tips on grinding? Being curved on one side and flat on the other is something I know I could use.
Re: parting tool
>Ruth, you should be able to use the planer blades, no problem. You will want to know whether they are HSS or carbon steel, either one will do but HSS can be sharpened on the grinder without losing it's temper--you likely know that already. A spark test on the grinder will give a multitude of bright orange to yellow trails for carbon steel, while HSS will produce a small, short trail of red/dark orange sparks.
Some planer blades I've seen have a small laminated strip of HSS for the edge, bonded to regular steel. If you look at an end, you might see a copper colored bonding line. These I would avoid for a parting tool but they will be OK for small scrapers.
The curved side doesn't have to be more than 3 inches long. I think I'd make the curves flatter on either side of the middle than what I have, and then round off the middle a bit. Round over each edge so they don't bite into the toolrest, and polish the blade all around on a belt sander with a fine grit belt.
This tool also comes in handy occasionally as a shear scraper for finishing off the bottom of a box, egg, or other end grain turning--cutting with either the curved or flat side.
Re: parting tool
Re: parting tool
RevDoug
>Mark, any chance you can post a picture of your homemade parting tool?
Turn 'em round,
Re: parting tool
Re: parting tool
>I forgot to mention that I also have a paring knife. One of these days I may put a longer handle on it. I have thrown it across the room once when the work grabed it.
Re: parting tool
Re: parting tool
>Yeah, Rev. Give me a couple of hours. I have company over.
Mark
Re: parting tool
Re: parting tool
>I posted this once, but it did not show.
Rev,
I was wrong on one aspect of my description, the sharp side is up, though I think it would be better if I had done it the other way around.
Mark
Re: parting tool
Re: parting tool
Bill Luinetti
>I use the Sorby fluted parting tool also (~1/16").
I asked Sorby directly about sharpening, and they told me that it is the non-fluted side (not surprisingly) that you whisper touch to the grinder wheel.
Bill
Re: parting tool
Nick Cook
Mike Brazeau
>In the AAW Pasadena DVD, Nick is doing Production Turning and for the Honey Dipper the tool he uses what looks like the Sorby 832H 2 mm Fluted Parting Tool. I just had a quick relook at the DVD, and didn't listen to see if he referred to it or not, but the shape and appearance is pretty much the Sorby.
Mike
Re: parting tool
Re: parting tool
Leslie S
>I have a parting tool with no heritage exceopt that it came in a box of stuff from a firend of my mothers who's dad used to turn. It's carbon steel and slightly diamond shaped and does the job better than any of the other HSS parting tools I have. I like the history of it and think of my Mom's friend's Dad when I use it and wonder what he turned using it...
Re: parting tool
bob davis
>ihahe had oneof those sorby thin tools for seversl years and used it as directed withe flute on the tool rest..i woke op recently and started using it with the flute up..as far as i am concerned tha is the correct way. you want that sharp edge cutting! file the short side with a diamond file..some people use agrinder. for smaller stuff i use the chris stott 1/16 parting tool
