REAL MILK PAINT
Bandsaw blade problem?
Carole Valentine
>I decided to put my new Highland Hardware Woodturner's Blade on my bandsaw today. First thing was the teeth were backwards and I had to turn the blade inside out. Then there was just no way this blade was going on my bandsaw - it lacked almost half an inch even though it was supposed to be a 105" blade. I finally gave up and put a new Viking blade from LV on there with no problem whatsoever. Anyone else ever had this problem with a new blade? Also wondering if having to turn a blade inside out weakens it?
Re: Bandsaw blade problem?
Ken Grunke from SW WI
><Also wondering if having to turn a blade inside out weakens it?
Carole, that's one way to find out how good the weld joint is! As long as you don't bend the blade, it shouldn't make a difference. I do know something else: turning a blade inside/out can be painful and a bit bloody. DAMHIKT.
Re: Sounds like you need a new tool,...
JamieDonaldson
>..a blade stretcher! You hang it on your skyhook for storage!!:-)))
Fog Tanner
>Carol, I store my bandsaw blades by twisting them into a figure 8 and finally a circle so they can hang on the wall. This was recommended by the folks at Suffolk (Timber Wolf). I always use gloves for doing this and outside with plenty of room. It does not appear to harm the blades in any way. but makes it exciting when you "unwind" them. I don't do that with my carbide blade though, I don't like the idea of catching one of the carbide teeth and ruining a $200 bandsaw blade.
I have never had a problem with blades coming up short, but I use either Timber Wolf or Olson. My father had a bad saw however that had an odd size and he could never find the right size blade, it was 1/2" off from the next size either way. Sounds like they just messed up when they made the balde and owe you one the correct size.
Carole Valentine
>Fog, I too store my blades that way. There is a big difference between coiling them like that (which is easy) and turning one inside out though, believe me! I managed to do it with no blood but had I known the blade was too short to begin with I never would have gone through the hassle.
Barbara Gill
>I coil my Wood-Mizer blades all the time. It does not hurt them.
Carole Valentine
>Barb, I originally tried to coil it (as I later read in your email) to get it flipped inside out but did not succeed. I finally stepped on the bottom and (with gloves) slowly flipped it inside out. I have no problem coiling for storage, but I could NOT seem to get it turned inside out (so the teeth faced the right way) through that method. You will have to show me when I come over.
Turn them inside out all the time
Brian Hahn in SW Wisconsin
>I turn them inside out every other time I sharpen a blade, then turn it right side out before putting the blade back on the bandsaw. I have one blade that has been inside-out and back again at least 30 times and it still works!
W.C. Turner
>I was a meat cutter for 30 some odd years, and all our BS blades came turned inside out. Doesn't hurt'um.
As for coiling the blades for storage, just place your left hand on the blade at about 9 o'clock, right hand about 3 o'clock, and sort of flip the blade toward you. When it starts to collapse, push your hands toward each other, & it's ready to hang up. With practice, anybody can master it.
W.C.
Where'd that edit button go?
W.C. Turner
>As I hit the post, I remembered this.
Easiest way to uncoil a stored blade, is to have plenty of room, in the yard is good, and just flip the blade up in the air, & let it uncoil all by itself.
W.C.
Re: Where'd that edit button go?
Carole Valentine
>As I said, I have no problem at all coiling for storage - a flip of the wrists and it's done. It was just getting it flipped "inside out" so the teeth pointed the right way that gave me a problem. It's a moot point anyway since the blade will not fit my saw.
Mkauder, Phenix City, AL
>Carol,
Call Highland and tell them the length situation, and they will make it right.
Mark
What am I missing here? I thought...
david
>that the bandsaw tension adjustment could allow for minor variations in blade circumference. A length of 1/2 inch in over a hundred inches seems to be easily made up in the adjustment feature. There are several methods of coiling up a band saw blade, and everyone seems to swear that his method is the best. But if you haven't done one in a while, you can mess it up pretty easy.
Re: What am I missing here? I thought...
Carole Valentine
>David, when I mount the blade, the tension lever (I have a Delta X5 with riser) is off (no tension)so the wheels are just close enough together to slip a 105" blade on. Some go on easier than others, but if the blade is too short, I just can't mount it. I have used many different blades, but this is the first time I have had a short one. I know HH will probably make it right. I just need to get around to calling them.
Hooligan
>Carole, on the tension lever is an adjustment knob. Loosen the setscrew, and turn the knob to allow a bit more space for the wheel to drop. On the X-5, it is should be the round piece, that the tensioning lever actually sits on, then there should be one that the lever pushes up against.
Anyhow, the rod going through the two is threaded, all you should have to do is turn it to allow the band to get on the wheels, and you should be good to go. I've run into it on my jet a couple of times, be the blades from olson, HH, Miser..doesn't matter. That's the purpose of the adjustment. Just make sure that you properly adjust the tension back to where it should be, when the band is on and "tight" before cutting.
Hooligan
>Uh, huh. After looking at the exploded manual that should get you there. Shout if you need.
>I would look at adjusting the saw as mentioned, but I would also measure the blade. Put a mark on it with a Magic Marker and carefully line up a tape measure with it and see what you get. If the blade is significantly short, I might not try to adjust the saw, but would deal with HH.
Look in the block in the saw that slides up and down and see it it has accumulated any sawdust. I'm just taking a wild guess, but I would blow it out if there were sawdust in it. I know it's not related, but I blow my planer out regularly and it really makes a difference.
Carole Valentine
>Thanks, I will check that out when I have time. I have already set up another new blade on the saw. I thought when the bar was released that was it, but I have never been one to deny the fact that I am somewhat mechanically challenged. :)
Leo Van Der Loo
Re: Bandsaw blade problem? Your right Barry
Leo Van Der Loo
>I've had the block hang up, forget what was the exact cause, but do remember that the blade did not fit, and it had been on there before, and found the cause to be the block not going down all the way.
Have fun and take care
Leo Van Der Loo
Stephen Mushinski
>Leo,
I was wondering if that might be the problem also. My bandsaw does the same thing and gets caught on the sheet metal cover not allowing the slide to come all the way down. I had to shim the cover and I also ground the cover so that I had full movement.
Hard to explain and if I remember imposible to photo without taking everything apart again.
Steve
