Work in Progress *LINK*
Darrell
>This is shameless advertising, except I have nothing to sell. I put up a "work in progress" section on my web page. this being a hobby I seldom have time to start and finish a cool piece in one go. This one has been on the lathe for a few days and I have spent maybe an hour or so at it. I think I am spending more time thinking about the next cut than doing it. Anyway, any comments are welcome. I should be breaking through the sides next.
Around the Woods: Work in Progress
Re: Work in Progress *LINK*
Mike from St. Clair Shores
>Darrell,
What does the other side of that blank look like? Is it bark also? If not get rid of the faceplate and change the center.JMHO
Mike
Tom Libby
>If the bark is sound, and you haven't tried one yet, how bout going for a natural edge? I'm a novice but here goes my opinion anyway...Not having a chuck, I'd of put a glueblock (with hot glue)on the faceplate, brought over the tailstock and used it till it wAS in the way, then brought the diameter down till the entire edge was within the bark.
Tom Libby
>Sorry, Darrell, I didnit look at the Name before I did the note.
Darrell
>Tom
I have no idea what the "sorry" was for but all is forgiven :-) In this case the faceplate was the safest of the options although the tail center could have been use at first. Actually, when the lathe was first turned on I was surprised how balanced it was. More good luck than good management on my part I assure you.
Around the Woods
Darrell
>Mike
The other side is where I removed the slab for the faceplate, if I have my orientation in the same plane as you are thinking. This will actually have the a natural edge, although there is no way the bark is staying on. I guess by natural edge I think of a sort of banana shaped bowl while this one will have a decided in curve and now much of a bowl in the bottom. More of a wing than I bowl I think. Of course I assume it will survive the turning. By the way, the third page is up.
Around the Woods
