THE WOODRAT IS BACK!
Finishing Advise
Finishing Advise
Finishing Advise
Jason Clark
>I'm working on the natural edge Box Elder burl shown below and would like some advise on how to finish the natural edge. Inside and out have been sanded and coated with Watco Danish oil, the outside has been Beall buffed as will the inside but as yet nothing has been done to the natural edge.
Advise? Leave it unfinished, Danish oil, spray lacquer, or something else?
thanks
Jason
Re: Finishing Advise
cagey59
>I always finish the natural edge the same as the rest of the bowl, except of course buffing. I use a toothbrush to make sure that the natural edge is fully covered with the oil and the wipe on poly that I use. The edge is done first and then the remainder of the bowl.
david
>Frankly, the most critical finishing element on this piece is how you are going to finish the bottom. The piece as pictured has a fairly wide base, and how much is available at the bottom to create a foot of having no foot at all will make a large impact on the overall form. Would like to see it again after it is finished.
Bob Fawcett
>I would darken the edges slightly.
Then finish with the same as you have on the rest of the piece.
Jason Clark
>The piece will lose the flared portion of the base, it's only there to provide a flat surface for the jaws of the chuck to rest against. The finished bottom will be 2-3/4", just over 1/3 the overall diameter of 7-1/2".
It looks like Danish oil without buffing is my best bet.
Thanks
Jason
Barry Turner
>I see nothing wrong with leaving it, as is.
GaryG in MD
>Jason,
Beautiful piece! I really like it.
You've gotten some good answers -- most of them different. Don't you love it? That's the whole point -- there is no correct answer. It's purely personal. I'm sure it will look nice no matter which method you choose.
If it were mine, I would leave it dull, just like it is now. I would like to have the contrast. I believe it will act as the main point of focus, and bring the eye to that lovely natural surface. For this piece, to me, that is most appropriate.
Please show us when it's all done.
Regards, Gary
Re: Finishing Advise *LINK*
Darrell
>Jason
I would use the Danish oil on the edges as well. I like to have a finish on pieces and generally use the same finish on the whole piece. If you go to the cosmetic section of your local dollar store or drug store, you can get a soft and long bristle brush for applying powder or blush. It will let you get the oil down into all the crevasses without hurting any thing.
Around the Woods
