Powermatic remote switch
woodnut358
>Does anyone use a remote on/off switch for their Powermatic 3520A? If so,Where is the best place to purchase one.Thanks!
Re: Powermatic remote switch
Brad Vietje
Brad Vietje
>I want to use one for my B-model, so I'm interested in the question, too. The PM remote switch is just on/off for now, and I was hoping for something that would have a speed dial and a reversing switch, too... As for a simple on/off, it might be possible to rig up a simple switch. Any problems forseen in doing that ? Is there more to this circuitry I should know ?
Safe spinning,
Brad Vietje
Newbury, VT
>I have the powermatic remote switch. I have had a problem with it every now and then. I think you can buy virtually the exact same switch from someone like Woodworkers Supply (I'll have to look it up for you). It's not for powermatic but is the same kind of switch. You also won't get the schematic for wiring it up. I can copy my wiring diagram for you if you aren't comfortable doing that. It's just wired in series with the hot lead going to the main switch.
I haven't looked into making a remote that has reverse and speed but it wouldn't be too hard to do if you wire around the existing controls. If you want to set that up so that both sets of controlls work it would be considerably more complicated.
Brad Vietje
Brad Vietje
>Thanks, John.
True enough, dual (dual-ing?) switches would get pretty cumbersome. I suppose the most useful thing would be a simple on/off for hollowing or bowl turning off the end of the bed, when reaching past the spinning wood would be best avoided. I'm perfectly happy wiring something up if you have the know-how. What I don't know is how graceful this sort of switch is in practice... will it allow the lathe to be simply switched on again, or does the inverter need to reset as it would if unplugged and plugged back in ?
Safe spinning,
Brad Vietje
Newbury, VT
>Brad Since the switches are in series as long as you have the main power switch on the remote switch acts as the on and off. Personally I feel a lot more comfortable using the remote switch out where I'm away from the piece on larger work. I stop often enough to inspect a piece that adjusting the speed is usually done then with the lathe off. I would like to have remote speed adjustment but haven't take the time to figure out the best way to do it.
Probably something similar to Oneway's system where you only have the remote switch.
Mike from St. Clair Shores
>I wired my own and it only cost about $10.00. If you need info on how to do it let me know by e-mail and i'll go into detail for you.
Mike
Has anybody done it on a Jet 1642?
Scott Hurley in N. VA
>I have a Jet 1642, and I'd like to do the same thing (after the warranty runs out). Does anybody have any experience with that?
Thanks.
Scott
Re: Has anybody done it on a Jet 1642?
Ed Karch
>Woodworkers supply has powermatic switches. Oneway remotes will also work or make your own. the owners manual has the schematic. Just take one wire off the main switch and attach nto mthe remote.The other remote wire goes where the wire came off the main.
Have you considered a foot switch?
Keith Newton
>I like being able to get my tool back into a hollow and find a little ridge with the motor off, and my toe poised over the switch, with both hands on the tool, and only 1/4" of movement, for the tool to be cutting right where I want it.
Would there be a hazard to a remote? where do you keep it, and how easy is it to get on by accident?
Mac
>As you probably know, the One Way remote has only on/off.I have found it to be a safer way to use the lathe.When turning the lathe on/off with the remote,you dont stand the chance of brushing the speed pot and changing the speed by mistake.I've seen people turn the lathe off with the switch on the post and not check when turning it back on,only to find they cranked it up without noticing it.I almost always use the simple remote one when shutting down,I find it to be a very good safety device......something to think about when you make yours......
Speed Pot
Bill Howatt
>I didn't like the location of the switches on my General 26020 when doing bowls, particularly roughing. I remoted the on/off and speed pot and I used the old location of the speed pot for an Off switch. This way I can turn the lathe off on either side of the headstock since the remote is usually on the bed side.
The On button with the speed pot on the remote is the only place you can turn it on so you can easily see the speed setting. I didn't bother remoting the Fwd/Rev because I don't use it that much, I would only use it sanding and by that time I am not overly concerned about the bowl flying off.
Bill
>I could not find the switch I was thinking about in Woodworkers supply. I either saw it somewhere else or they've quit carrying that model. They do have several different switches that would work including a foot switch. I'll keep looking this weekend. Maybe I'll remember where I saw them. They looked like the exact same switch as the powermatic but about half the cost.
Sounds like a personal question!
Bob Fawcett
>I have the factory switch on my PM3520b. It is simply connected in series with the main switch in the headstock. The instructions are downloadable from the PM website. They are in the manual for the B model here: http://www.wmhtoolgroup.com/partfiles/m_1352001.pdf
You could easily make your own. Just a switch and a box with a short piece of wire. The factory switch has a magnetic back so you can attach it to the lathe. Just install a small rare earth magnet in your box. The switch can be almost any single pole switch you like as long as it is rated for 250V.
Re: Powermatic remote switch *LINK*
>Here's another possibility. On a 110 motot this will simply plug in. It could also be rewired pretty easily to just use the switch which is probably the same switch used on the powermatic remote. It doesn't have a magnet on the back but it would be pretty easy to epoxy a big rare earth magnet on the back. The quarter size rare earth magnets are really strong. I get them from Lee Valley
http://www.woodcraft.com/family.aspx?familyid=5002
Darrell
>Have you considered something like this as a footswitch?
http://aroundthewoods.com/switch.shtml
I use it for hollowing all the time.
Around the Woods
woodnut358
>Thanks all--I found one at Osolnik Machinery..
