Lathe height/ Arm Pain Question?
>My lathe is set up so the shaft is about the height of my forearm if I hold my arm level. I have what I would call a 'snarled muscle' in my back between my shoulder blade and spine. (right side and I'm right handed) What are the chances there is a relationship? Would it help if I raised or lowered the lathe? There seems to be a 'nerve pinch' aspect to this and it may be affecting the strength of my arm and hand.
Re: Lathe height/ Arm Pain Question?
Allen Neighbors
>"forearm level"... does that mean with elbow bent, or arm straight out from the shoulder?
When I turned on Old Griz with the spindle at 46" (I think), my back and shoulders gave me fits all the time. I set the spindle on the 1640 at 49". No back pain or shoulder pain anymore. I love it.
Sometimes a small change will make a large difference.
Allen
>I also have my lathes about an inch or slightly more above elbow height. Don't know how long you've been turning but I've learned to relax more as the years have gone buy. It used to tire me out and my arms and back would hurt. Now I can turn all day with little pain other than my feet. Maybe lathe height along with relaxing my grip has worked.
And hollow vessel turners often ..........
Jamie Donaldson
>.....benefit from a higher spindle height than bowl turners. Adjust any lathe to whatever height seems comfortable to the specific user- it's unfortunate more lathe manufacturers don't incorporate height adjustment in the design process.
Re: And hollow vessel turners often ..........
georgetroy
>I'm in the lower height lathe camp. My heights on lathes are set from 42"-43". Height approx. 5'9". My strenght; what there is left is at my waist and belly button. If my arms are flapping in the breeze they will ache. My lathe position is compact using the weight and strength of my lower body for me this a very powerful position and one I can use all day with out aches and pains. GT
Dick Hines
Dick Hines
>Barry you could get your lathe up there with mine. My PM is at 50". Of course I am 6'5". Do you remember Carloe trying to turn one of he minies. Standing on a milk creat and complaining about the lathe being to high.
Nick Tuzzolino
>For what it's worth, that sounds about right. I'm just over 6' and I turn at 45". Seems fine so far.
>Gosh I'm 5'7" and my lathe is 44 1/2".
tm
>I'm 4' 6'' and my spindle is @ 45 1/2,
shrug....
tm
Rrecommend you consult a good
David
>physical therapist. I have a similar problem, and the diagnosis is that I need to do some exercises to strengthen the back muscles to counteract the forces generated at the lathe that are causing the back pain and in my case aggravating elbow tendinitis. It is difficult to get me to exercise, but if it will keep me active woodturning, you better bet I will do the exercises!
Re: Rrecommend you consult a good
W.C. Turner
>David, and others, as well. I've had low back problems for years. I used to depend on my chiropractor for re-alignment. But, since he retired, I started to do a lot of walking for my exercise. Yes, just plain old, simple walking. Try it, and you may find like I did, that my back feels much better now, because of it.
W.C.
Re: tm, you're a card!
Allen Neighbors
