Re: Vacuum Pumps
Fog Tanner
>I bought two dual cylinder pumps from a club member for $80 for the pair. I spent another $20 in fittings and bearings, part of that was for some pieces I wound up not needing. I made an adapter, and then my brother inlaw made me another one so I wound up not using all the pieces I bought. The highest cost was in getting brass fittings, I could have used iron, but brass looks cool. I bought the filter, guage, and some of the fittings from Surplus Sales.
For vacum chucks, I bought five of the face plates from John Nobel. I made the chucks from MDF and PVC coupling fittings. The faceplates were 5 for $25, the PVC fittings run $4-$10 and the MDF was left over from another project. I could have saved on the PVC fittings and stacked some MDF rings, which I am planning on doing - a segmented chuck :-) .....
There are a couple of club members that use the compressor out of old refrigerators for their setup. They will pull enough vacum, but the problem is volume - takes a long time and you can' have any leaks. Which can also be a good thing - another of our club members had needle valve instad of a higher volume value for bleeding air into the system. He turned the pump on (a 220v Gast from Surplus Sales) and before he could open the needle enough, his bowl got sucked into the chuck.
