Re: screeching banjo
Jim Pugh, Elyria, OH
>A slightly different response and one that I do in additon to the various lubricants (I use WD-40 most of the time) is to take the banjo off of the lathe, lay it upside down, get a fairly fine file and file all edges of the bottom surface. Just run your fingers around gently and you will find plenty of sharp edges. Do inside edges, outside edges and any other edges that might be there. It is then a good opportunity to spray/wipe the entire bottom surface with the lube of your choice, including the shaft that runs from front to back. Now, it may not be less screachie (?) but I'll bet it will slide easier.
