Largest Bowl Smaller Now
Allen Neighbors
>Well, I did it. Knocked a chunk out of the rim. What a klutz! That will make it about an inch smaller in diameter, and an inch and a half shorter.
Saved the piece, but didn't want any glue lines.
Allen
Allen Neighbors
Allen
Re: Largest Bowl Smaller Now
Kurt Rosenzweig
>It's gonna be a beauty anyway! Make sure you post pictures of the finished peice!
Allen Neighbors
>Well, I turned it smaller, and a crack appeared where I'd knocked the chunk out of the rim. So I filled it with crushed turquoise, along with a few smaller inclusions.
Allen Neighbors
Re: Outside
Allen Neighbors
>This is a shot of the outside, showing the filled areas.
It's already 17 X 16 inches, ovating rapidly, by 5 inches deep. Two coats of Salad Bowl Finish. Now, I have to finish the bottom.
Allen
Allen Neighbors
>Thanks, Kurt. Hope it doesn't crack anymore. I don't care how it moves, as long as it doesn't crack. :o)
Allen
Carole Valentine
>Looks like the chunk came out along a growth ring. That's a shame, but the other pics look like you made the best of the design opportunity! :)
Mike from St. Clair Shores
>Allen,
Looks like you tackled that bowl head on. I know you were nervious before you started, but don't you feel like you accomplished something? The piece that came out, I was wondering if I could see some chatter marks. I like to use a steady rest for bowls that big. Or else I turn near the rim to finish dimensions, and move toward the bottom and try not to go back. That's where I run into trouble with chatter. But you pulled it off and the final piece looks great.
Mike
Allen Neighbors
>Thanks, Carole, coming from you that means a lot.
Allen
Allen Neighbors
>Mike, thanks for posting.
I tried to turn to finish thickness as I hollowed it out, and then decide I needed to scrape it a little smoother. My bowl steady isn't large enough for this lathe, and I haven't made another one, yet. :o)
I got it down to 1/4" thick, and it was warping on me as I turned it. I kept spraying the outside of it with soap solution ever so often, to maybe keep down the cracking and warping. I hope it helped some.
Thanks for the comments.
Allen
Doug Thompson near Cleveland
>Allen, you got past the problems and it turned out very well. I agree, one or two inches at a time and never go back. Calipers do help.
Good Job,
Doug
Leo Van Der Loo
>Hi Allan
You did pretty good, yes big bowls are a whole other story aren't they ??
They really start to flex as the bottom gets thinner, it's not as bad if you can keep some more meat in that part of the bowl, until you have done the upper part, a bowl steady can help, but shrinking/warping can make it a real challenge in a hurry.
I hope you packed it in some paper or other "slowing it down drying" way.
Have fun and take care
Leo Van Der Loo
Ron in Drums PA
>That looks real good Allen!!
Well Done!
Bob Elliott
>Allen,
Nice save!
Looks like that 3-4" face plate worked after all. Now the fun begins...watching it move.
Allen Neighbors
>Thanks, Doug. I do use calipers to guage the thickness.
Allen
Allen Neighbors
>Thanks, Ron. I put the final finish on the bottom a while ago. When it's set long enough, I'll buff and post the finished pic. It has surely gone oval on me. :o)
Had a heck of a time getting it jam-chucked for bottom turning. All my jams were made for Old Griz, not my Oneway.
Allen
Allen Neighbors
>Leo, thank you. You're right about large bowls being different. the word "wild" comes to mind. :o)
While turning the inside, I sprayed the outside occasionally with some soap solution, to slow down the drying of the outside, and to prevent some cracking. But after I got the inside turned to 1/4 inch (6mm), I just let it go. I like the way oak moves when it's drying. :o)
Allen
Allen Neighbors
>That's it! :o)
Allen, You have a huge problem !
Brad Vietje
>Allen, your lathe is way too clean (note the Formula 409 in the background)! If you would be so kind as to ship it to me, I'll be more than pleased to dirty it up a bit for you ;^)
Great save on a nice-lookin' bowl there, Allen !
Safe spinning,
Brad Vietje
Newbury, VT
Re: Allen, You have a huge problem !
Allen Neighbors
>Brad, Sorry, I think I'll be able to dirty it up myself. :o) However, I do take the time to clean off the spills and splashes of soap, CA, and finishes. I waxed the whole thing to start (at someone else's suggestion) and it makes it easier to clean.
The 409 is just the bottle I use for spraying the soap solution on the outside, while I'm hollowing out the inside... it helps to slow the drying and cracking.
Allen
