Veritas Burnisher
W.C. Turner
>1) Anybody tried one one of these for Woodturning Scrapers?
2) How do they work?
3) Satisfied?
4) Anything else to add?
Thanks in advance!
W.C.
Veritas Burnisher
W.C. Turner
3) Satisfied?
Thanks in advance!
W.C.
Re: Veritas Burnisher *LINK*
Ron in Drums PA
>W.C. Asked
Yes
Good
>>3) Satisfied?
I like this one better
http://www.woodsmithstore.com/cabinetscraper.html
Wilford Bickel
>WC,
I got one about 3 weeks ago from Lee Valley and so far I am well pleased with it. A little learning curve to get the right movement against the pin to form a good solid burr but a few tries and I had it going. Make sure where you order from will send both the 5 and 10 degree pins - makes a difference depending on the bevel used.
Fog Tanner
>I have and use one. It does not produce a "burr" as you would in grinding. It burneshes the edge or curls it upward, actually moving the metal in place of a fragile "wire" made of ground metal. It turns the edge of the tool upwards and creates a cutting edge. The amount of the cur can be varied by using one of the carbide posts, each has a different angle, and how hard you press the tool against it.
You have to learn what is right for you as it can be much more aggressive than what you get off the grinder. In my usage, the cutting edge stay long than the one produced by a dry grinder.
>Cabinet scrapers weren't designed to use an edge straight off the grinder. The burr that you raise by hand is much stronger. I have always sharpened mine by hand. There is a definite learning curve to establishing a good burr that cuts well.
Mike from St. Clair Shores
>I use mine all the time. I first sharpen the scraper, then use a diamond hone to get rid of the particles on the top of the scraper( it may feel like a burr but its not) Then I burnish to raise a burr and when you do it right, you can really feel it and it cuts a nice fine ribbon and last quite a while.
Mike
eliot
>Wilford,
I was going to add that it helps to hold the edge of the scraper up a bit from the base of the burnisher so that the burr that's raised is not so steep. but from your response, it appears that the pins you have are already angled. Mine are not . I must have an older model. Do I have this right? Are the new ones provided with a couple of pins with different bevels?
GaryG in MD
>eliot, yes, that's true. ...Gary
Richard Allen
>Honeing the top of the scraper before burnishing will help you develop a better burr. Most scrapers do not have the top surface honed. Working the top sufaces so that it is flat by honeing will provide a more consistant burr.
Bill Neddow
>If you decide to get one, be aware that they are very efficient tools. I got one eight or nine years ago, when they first came on the market. I leaned on my scraper when I burnished it, and got a great edge -- so great that it worked like a fish hook. It grabbed every piece of wood I touched and some of the catches were monumental.
The burnisher is a great tool, but it took me quite a while to realize I had to be gentle to get the best results.
Wilford Bickel
>Eliot,
The unit I received from Lee Valley had a 10 degree pin and a 5 degree pin so you keep the tool flat on the surface and let the angle of the pin do the work.
Forgot to add
Wilford Bickel
>they also list replacement pins so if you have the older model you can probably just purchase the angled pins if you wanted the newer style.
Ron.....
W.C. Turner
>I was speaking of the one for woodturning scrapers. How do you use the one in your link for woodturning scrapers???
W.C.
Thanks for all replies thus far!!
Ron in Drums PA
>This is what I thought you where speaking about.
It's used to create a burr on cabinet scrapers
http://www.woodcraft.com/family.aspx?familyid=3739
Re: Nah ;) *LINK*
Ed in Leaside (Toronto, Ontario)
>They're talking about this one.
I have one and it does what it's supposed to do.
Re: Nah ;)
Ron in Drums PA
>Thanks Ed
Re: Nah ;)
W.C. Turner
>That's the one. Thanks Ed.
W.C.
eliot
>I understand; I'm disappointed that mine ( an older version) came with straight pins.Consequently, it takes a certain amount of extra effort to burnish an edge that's not too steep. Possibly one could get some hard material and grind and polish something. (Then again, I'll probably spring for a new one.)
W.C. Turner
>Bill Neddow, and all the rest of you that have this tool, do you still use it?
W.C.
Re: Forgot to add
eliot
>Thanks; that's just what I did. They're on their way.
Ever since I attended a demonstration by Don Derry, I have been sold on grinding followed by honing away the wheel- produced burr, followed by burnishing with hard pins. Derry sells a fixture with straight pins and talks about angling the scraper upwards while burnishing so that the raised edge is at a better (less steep) angle; but using a pin that's beveled to begin with seems like a superior method. Derry asks, "Why would you want to scrape with a ragged edge?"
