Bad Platter, Sewed Up
Allen Neighbors
>Got into this bowl, and it was so bad, I made a platter. I intended to fill the inclusion with turquoise, and the more I turned, the worse it became. So I finished it, and sewed it up with copper wire.
Didn't know what to do with the ends, so I just twisted them, and curled the rest.
There is another spot on the edge that is filled with coffee and super glue.
Comments?
Allen
Re: Bad Platter, Sewed Up
Re: Bad Platter, Pic 2
Allen Neighbors
Re: Bad Platter, Back side
Allen Neighbors
Re: Bad Platter, Back closer
Allen Neighbors
Steven Antonucci
Like it, but lose the curli-ques
steve antonucci
>and maybe a slightly heavier gauge wire to make the copper stand out better...
Steve
Barbara Gill, Remlik VA
>Allen, that is real interesting. Another treatment would to make it look like an open zipper. I can't remember which turner uses the zipper idea.
Re: Steve, that is
Allen Neighbors
>the same thing I thought as I was taking the photos. I may do that later this evening. How would you tie up the ends?
Allen
Re: Sounds good, Barbara, but...
Allen Neighbors
>How do you do that?? Just use a larger guage wire, and wrap it around the sides only?
Allen
>I don't have a clue Allen.
Bill Stehman
>Allen,
Great save and I like it. Maybe what Steve said .... bigger wire but I really don't know.
bill
Carole Valentine
>What a design opportunity, Allen! I like it. I think I would have chickened out on turning it though. You are a brave man, indeed!
Geeeeshh!!!
Mac
>You go to a gathering,buy a new, fancy lathe , and you go all artsy on us.
>Have you seen the ones "repaired" with a leather shoelace? I think that is actually a real technique used one working bowls.
How about on yours you start at the outside edge and go toward the center? Then when you get there, drill two more holes the size of the wire that do not go all the way through to the front. Insert the ends of the wire into them and glue them in with CA.
Re: Geeeeshh!!!
Allen Neighbors
>I wish.............. :o)
Allen Neighbors
>Barry, I'd seen those before. I gave my Sister one of my bowls that she picked out last November... one turned from White Oak, that had a terrible gash/inclusion filled with turquoise... (I turned it wet, and let it dry and warp). She loved it. Took it to New Mexico. It warped more, got all bumpy inside and out, and let out a loud "Cra-a-ck" one evening. It split more, along the side of the turquoise. She brought it back Wednesday, and I laced it with leather. :o)
She still loves it! I'll try to get a pic of it, before she goes back.
Allen
Ron in Drums PA
>Great Save Allen, this one is excellant!!
Re: Steve, that is
Don Evans
>Drill a hole same diameter as the wire, loop the wire in sort of an arc and put the end into the hole. It just disappears from view that way and everyone will be looking on the bottom to see where it goes.
Further explanation, don't drill all way through, just enough to hide the end of wire, put little epoxy in hole before inserting wire end.
Don
Re: Thank you...
Allen Neighbors
>Thanks for your comments and suggestions, one and all.
I've got to come up with a decision, now. :o)
Allen
Re: Bad Platter, Sewed Up *LINK*
Mike from St. Clair Shores
>John Lucas was talking last week about a turner named Paul Stafford. Although I also like what you did Allen.
MIke
http://www.woodturner-gallery.com/zipperturnings.html
Ric Taylor
Re: Like it, but lose the curli-ques
Ric Taylor
>I agree about the curli-ques, but I like the thin wire.
Ric
Re: Leather Stitching
Allen Neighbors
>This is the one.
tried rawhide?
TDaniel
>Al, I use rawhide strips to lace cracks. I get it from Jack White leather products. I soak it in water for a couple of hours before using it and then lace with it wet. As it dries it shrinks and tightens up. If you tuck the ends back under they will not come loose once they are dry. It is available in 1/16" and 1/8" strips about 3 ft long; I prefer the 1/8" but then I don't do small vessels very often. Let me know if you need contact info.
TD
Re: tried rawhide?
Allen Neighbors
>TD, thanks for the suggestion. I've used wet rawhide for other things before, but my Sis lives in New Mexico, and really gets into the Southwest stuff. She's going to put a couple of beads on the ends of these and put it on the mantel with some other SW style things.
Allen
Re: I'm a coward at heart...
Allen Neighbors
>and mostly looney at other times. Duct tape works wonders. :o)
Thanks, Carole.
Allen
