I'm thinking of building a rubber room.....
Dave Belser
>. . . with my buffing wheel sticking through a hole in the wall!
I use the Beal 3 on lathe wheel set and I can't tell you how many times I've had a piece ripped out of my hand and slammed into the lathe bed and then the cement wall behind. This must be one of those things most of us experience on occasion.
I'm getting better at it. Tonight it was just a mahogany top so I didn't have a lot of time into it. I've also learned a neat trick that may or may not be common knowledge. If you have a dent or crushed spot, get it very wet and then apply heat from an iron. I use a hobby iron left over from when I built RC planes it's used to iron on the heat shrink covering. I set it at it's highest. The water should sizzle and steam out, but don't burn the wood.
I'm always amazed at how well this works on removing dents. It can take *many* cycles of wet and iron, but I have managed to coax some very serious dents out, to the point where they disappear. As long as the wood fibers are still intact, in other words no missing wood.
On the other hand, that rubber room might be useful when I need to settle down :)
- Dave
Re: I'm thinking of building a rubber room.....
>Dave what speed are you buffing at. I buff pretty slow, probably 1000 rpm or so. I've only had one piece pulled out of my hand in the last year and that was me being stupid. I know how you feel. Maybe we could develop a net kind of like the ones that go around the new trampolines. Then of course we need rubber lathe guards.
Or a net to catch a piece before the second bounce
David
>My horrors are a catch while finishing the bottom while on the vacuum chuck. Bounce off the ways and on to the floor behind the lathe. Ouch! It hurts when it cracks near the final finishing.
800 - 1020 RPM
Dave Belser
>Not sure the exact speed without checking. I have my old Delta lathe with the step pulleys setup with the buff wheels most of the time. It's really a matter of paying attention. I'm usually pretty excited about the way buffing brings the best out of the wood. As long as you don't let a top edge get caught by the wheel and keep a good grip everything is OK.
I might actually get a rubber mat to lay over the lathe bed, but really I think is just a matter of paying attention.....
- Dave
Re: Or a net to catch a piece before the second bo
Dave Belser
>That's another great way/time to destroy a peice. Your finishing up and it looks great, so you say "Yeah, that will PROBALY hold it while I finish the bottom...."
Why, after spending all the time to make it just right, do we rush to finish the bottom?! I'm getting better, but boy you'd think after the first time that one would learn...
Re: 800 - 1020 RPM
Carole Valentine
>Wow, I buff at 1800. Higher with the bowl buffs. The buffs will get more "grabby" if you have too much compound on them. I always try to buff with the edge of the piece down. Also, if it's a particularly slick piece I will put on a pair of nitrile gloves.
Russ Fairfield
>Run slower, keep sharp edges leading away from and below the center of the wheel, and hold on tighter
Leo Van Der Loo
1725 RPM on this
leo Van Der Loo
>Dave I have no lathe bed or other obstructions close by, to slam the turning against.
I picked up a $5.- electric motor at a garage sale, and coupled a jacobs chuck to it, I already had my buffing wheels mounted individually, as I use them to buff turnings while still on the lathe as well, with a high speed drill.
I made a picture from the motor setup some time ago, and it was just sitting out of the way, it can be clamped onto a corner of a work bench or on a dedicated post, it works well for me, and if you use a keyless chuck, the switching of the buffs would be even faster.
Just a other way of doing it.
Have fun and take care
Leo Van Der Loo
Safety Net Catches Them
Ron McKinley
>I have lost a few that way so I pulled up a small folding chair beneath the buffs and put a plastic container that I found at a garage sale and lined it with dryer sheets stuffed in a plastic bag. So far it has caught three with no damage.
I use the dryer sheets for cleaning my face shield so they are always handy and serve double duty.........Ron
Phil Powell
>I've thought about a rubber room several times lately. Not because of my buffer, but
because of all the money I've spent becoming a turner. My rubber room is needed for
a completely different reason..............if my wife knew.......I could trade that room for
a pine box.
Dents - silver lining
Rick Allen
>The silver lining could be the steaming to remove a dent.
You can purposefully dent wood, sand away till the dents are gone (flush with the sanded surface) and then steam the piece to produce bumps. It is a wonderful texture. You can take the dents one more step and use leather stamps to dent the wood which will result in the stamped images raised on the wood (need to be done to a flat surface like the rim of a platter. You also need a LOT of force to dent wood with a leather stamp. I have used a 6 ton press.)
False economies
Dave Belser
>My post was more of a rant than a request for help - but as usual the advice and suggestions have been great.
I bought the "3 on lathe" system to save a few bucks about a year ago. Having never buffed before, I wasn't sure how much use it would get. Now almost everything gets buffed so..... Most of my buff tosses come from one of two reasons:
1. Buffing small items that are hard to hold, in the future I'll try using nytril gloves like Carol suggested.
2. Trying to work bigger items around the adjacent wheels and lathe. The 8" buffing wheel don't leave much room on a 12" swing lathe. Here is where the false economy of the "3 on lathe" is the issue. I figured I'd save money and space in my small shop but that's not much good if you routinely smash pieces into the lathe!
So I'll be scouting the yard sales for a 1750 RPM motor and saving up for a set of independent buffing wheels.
Another false economy - I bought two tool rests and one post, one of the modular systems. I really needed the two different rests and figured, cool I can just buy more unique rests as I need them. Well guess what, the two rests were needed for specific steps when I make my Cryptex Tantalus and I constantly have to change the rests on and off the post! Duh. I now bought another post. Kind of like having all those jaw sets and only one chuck. It took less than a year for me to buy a second chuck.
- Dave
Re: Dents - silver lining
Dave Belser
>Thats a technique I'd like to try Rick. Do you have pictures of examples ? Alan Lacer talked about using a metal/welding tool, a descaler I think? for texture on tool handles, it made lots of little dimples. Could be interesting to try this with the sand and steam approach.
Re: False economies
don in central IL
>I just purchased the Beal system this weekend and only had time to buff one small piece. The problem I am having is knowing how much is enough when loading the wheels. The tripoli seemed fairly easy to 'see' how much was loading but I had a problem with the white diamond and the carnuba wheels no know how much was getting on the wheel. I think once I learn a little more, I'll love the buffing. How can you tell when the wheels are properly loaded? TIA
Re: False economies
>Don I use almost none. Just one or two quick swipes across the wheel. My White diamond and Wax wheels still look new except for all the misshapen threads. Even my Tripoli wheel is still light tan. I found out early on that I just didn't need a lot of the compound on the wheels.
Re: False economies *LINK*
Stuart Johnson
>I have the Beal system and when I decided to try a 3 wheel system I built one. You can see it below plus there is a link to a pdf file showing more details.
I don't see why single buffs couldn't be made just as easily. Just cut some 1/2 inch all thread to the length you want and adjust the buffing wheels.
3 wheel buff
s/b 3/4 not 1/2 inch all thread
Stuart Johnson
Roger
>Surgical gloves can help you keep your grip. I used up all my bad words and came up with a few new ones with buffing screwups.
Re: False economies
don in central IL
>Thanks, John. I probably loaded up the tripoli a little too much and possibly the others, but it'll work out in the long run I'm sure.
Paul Porter
Don't change hand positions...
Paul Porter
>...with the wood up against the buffing wheel. Pull the piece away from the wheel, change hand positions, hold on tight and go back to buffing. Since I have been doing this, I haven't had a piece pulled out of my hand. Give it a shot.
