What I did to my Powermatic 90 *LINK*
Ben Aragon
>Lathe Variable Speed Modifications
I did this in steps
I replaced the motor with a Dayton 3N486 2hp, 3ph. I got it new on EBay cheap.
http://www.grainger.com/Grainger/wwg/productIndex.shtml
I bought a 1ph to 3ph speed controller. Square D model Altivar 11. The controller is mounted in a box to protect it and has a door with a window to see the speed, door not shown in photo.
http://www.us.telemecanique.com/products/Motor_Control/Adjustable_Frequency_Drives/Panel_Drives/ATV11/index.html
Replace the reeves pulley system with multi-V step pulleys. I bought the pulley from WWS in Washington. They are the step pulleys used on the WWS No. 1 lathe. Talk to the guy that sells parts for the lathe not the retail store. The reeves pulley will slip when turning large diameter stuff, it woks well for spindle turning but not bowl turning especially one with a raiser block.
The step pulleys are 1.75�, 2.75�, 3.75� set 1 and 5.25, 4.125�, 3.375� set 2. I looked all over for this type of multi-V pulley and this was the cheapest route I found. The multi-V belt will greatly increase performance. I also had to make adapter bushing so the pulleys would fit the spindle and motor shaft.
I mounted the motor on a hinge plate off the raiser block. This enables me to move my headstock up and down the lathe. I can turn large diameter stuff if the headstock is moved to the tailstock end or I can turn facing the bowl.
Speed and direction box are on long control cable with rare earth magnets on backside , so I can place it anywhere on the lathe.
You can go the DC route it is better but it does cost more money. I went this way because it was what I could afford.
Hope this helps
Ben
SQUAE D Altivar 11 Controller
