spray lacquer problems
>I having one heck of a time spraying my lacquer now that summers here. I use Deft brushable lacquer and thin it about 50/50 with lacquer thinner. All of the sudden I'm having a really bad problem with Orange Peel. I've thinned it more and no dice. I did change spray guns. I had one of those cheap HF touch up guns and dropped and broke it. I bought another one so it could be the gun or it could be the Humidity. Would retarder help or do I need to just play with the spray gun more.
Re: spray lacquer problems
Re: orange peel
Mike Nelson
>John, I build and finish cabinets using mostly lacquer. Thinner makes it dry faster.This is what causes the orange peel look. Use retarder, increasing the amount till you get a good finish. Mike
Russ Fairfield
>Orange peel is the result of partially dry droplets of finish hitting the wood surface because the thinners have started to evaporate while the droplets in the spray mist are airborne. Use a retarding thinner, use less pressure and hold the gun closer to the surface, or wait until October.
Dinyar Chavda
>OK, I'll bite. What's a retarding thinner--I mean I can guess what it does, but is it called a retarding thinner on the package, or something else?
Russ Fairfield
>Yes, it says "Retarder" on the can.
You can get some of the same retarding effect by adding a little turpentine to the thinned lacquer and mixing it well. I can't tell anyone how much to use, or how small is "a little", but start with 1-Tablespoon in a pint of thinned lacquer and don't increase the amount by more than 1-teaspoon at a time.
Mark Kauder, Phenix City, AL
>John,
I agree with everything that Russ said, but try all his suggestions w/o the Retarder first.
The reason that I say that is: Deft, being a brushing lacquer, has one heck of a retarder in it already - it is the reason that I stopped using it - took too long to dry to a sand-able condition.
If you can, I would change to a better quality lacquer like Behlen's Stringed Instrument Lacquer. Higher solids content, abrasive resistant, but still flexable enough to move with the wood. Even though it is about $9 a quart, is really cheaper than Deft, because you will apply about 1/2 - 1/3 fewer coats because of the high solids content.
Also, if it is an option, try a cooler climate for your spraying, i.e. spray early in the morning or in an air conditioned climate. Just ten degrees cooler will make one heck of a difference.
Just my opinion, with not near Russ's experience.
Mark
>Thanks guys. I may be using too much pressure and too much thinner. Seems like I read somewhere that thinning would help reduce orange peel. For some reason I raised the pressure a while back. Maybe to try to atomize the spray better. It seemed to work at the time. Anyway I can try that today. I'm headed to Atlanta next week so I'll pick up some better lacquer and get some retarder while I'm there. That will let me play with both and see what works for me. I'm in roughly the same humidity as Mark although it's usually hotter down there.
Speaking of Heat. I've got to stop and mow the yard. Hate to do it now but I can't do anything else in the shop until glue and finish on the current projects dries. I would love to get these projects done before I go to Atlanta.
Mike Nelson
>John, I've also found that the faster you can apply the lacquer (and stay in control) the smoother the finish. Maybe its the extra few seconds for the lacquer to 'melt' before it sets.
Leo Van Der Loo
leo Van Der Loo
>Hi John, it's been a long time since I did any spraying, but I would blame the Orange peel on the paint droplets not being able to flow together, a slower thinner and a bit more thinner might be helpful, also the paint quality has a bearing on that, and yes I had some unpleasant experiences with very high humidity, do you have a drier in your airline ? water vapor also can trip you up, just some thoughts I have on it.
Have fun and take care
Leo Van Der Loo
Allen Neighbors
>John, I buy Clear Gloss Lacquer by the gallon. If I can get pre-catalyzed lacquer, I get that. Pre-cat is a high solids lacquer that you don't even have to thin, and it is wonderful! You can thin it, but you don't have to. When I use it I never get a run or orange peel.
With normal lacquer, you have better flow-out, and less chance of orange peel or blush if you use Retarder (I buy it by the gallon, also). I apply the retarder at the rate of 3/4 film cannister per cannister of lacquer, and one gallon lasts me about a year, now. I have used the same old Buffalo Spray gun for about 10 years. I spray with about 30-32 lbs pressure.
If I thin non-precatalyzed lacquer, I put the retarder in the cannister first, then the thinner, then the lacquer. The Retarder mixes better in the thinner before the lacquer is put in.
Just the way I do it. Hope this helps.
Allen
>Thanks everyone. My best friend has a local place to buy pre-catalyzed lacquer. I may talk him into getting me some when he goes back. He doesn't seem to have the problems I have but he likes a really thick layer in one spray and it doesn't look as good as many thin layers. I guess I could probably thin it.
Forget the Spray Guns, Use Spray Cans
Barry Turner
>Forget the cheap spray guns and just buy the stuff (Deft) in spray cans. If you are finishing mostly small items, its almost not worth the trouble to use a spray gun, what with all the cleaning and stuff you have to do to get aceptable performance from a spray gun. Deft spray cans have a better nozzle than most. I have been able to get quite acceptable results with Deft spray cans. When you are finished, just invert the can and spray a blast of proplellant and you're finished. No cleaning........no compressor noise.......no fiddling with the adjustments on a spray gun.
Deft in spray cans may cost a bit more, but when you factor in the costs of thinner for cleaning spray guns.......and the costs of maintaining a compressor, the cost advantage narrows.
Back to spray guns. I have a Binks # 7 that I use occasionally. I never spray with more than 30 lbs. of pressure. That's plenty. If you are finishing larger items or a lot of small ones, using a spray gun might make sense.
Allen Neighbors
>John, I neglected to tell you that I clean my spray gun about twice a year, and until cleaning, never empty the lacquer out of it. I just take it off the hook, connect the air hose, and rub my finger across the nozzle, and spray. If it seems like it may be clogging a little, I take the nozzle off and drop it into a small jar of lacquer thinner for overnight, and wipe with a paper towel.
It's much cheaper than the spray cans, but I have used them, also... I just can't get the type of lacquer I want in a spray can.
Allen
Re: Forget the Spray Guns, Use Spray Cans
Allen Neighbors
>Barry, see my post, above about cleaning my gun. Just info. :o)
Allen
Mike from St. Clair Shores
>John,
This may seem like an urban legend and I'm not 100% sure if it's true, but when I worked as a builder in a custom furniture shop, SILICON was not permitted anywhere in the building. They said it never evaporated and would travel endlessly around the shop. It was considered the major source of orange peel when spraying lacquer. Myth or Legend? I thought I'd throw it in the mix since nobody else mentioned it.
Mike
Krylon has more solids than Deft
Phil Joines Krum, Tx
>You need fewer coats for the same film thickness.
Re: spray lacquer problems *LINK*
Russ Fairfield
>I see some wrong information starting to creep into this discussion.
Silicones are not a myth, and they can be a problem; but they don't cause Orange Peel. The silicones cause what is called "Fish Eye" because that is what it looks like. "Fish Eye" is a contaminate problem on the surface of the wood. It is a condition where the lacquer refuses to form a film on the surface, and instead pulls away from a circular area, and forms a ring of lacquer around it. We usually blame oils, but there are number of other things that will cause "fish eyes" on the surface - finishing oils, silicones from furniture and automotive polishes; but finger prints and body sweat in hot weather are the 2 major causes.
"Orange peel" is is the result of the thinner evaporating too fast, and the spray droplets form a skin on their surface between the nozzle and the surface. This skin prevents them from flowing together on the surface.
"Blush" is a humidity problem. It is condensed water vapor from the atmosphere. It can be condensed moisture from the air caused by the pressure drop at the nozzle, or from atmospheric moisture that condenses on the surface from the cooling of the film that is the result of the cooling from the rapid evaporation of the thinners.
The only solution that I know of for preventing "Fish Eye" is a clean surface, and don't sweat. Clean the surface with lacquer thinner before spraying, and don't touch it. I spray an extra thinned coat of lacquer and wipe it all off before it dries, thus removing the contaminates and leaving a primer coat of lacquer on the surface.
The only solution "Orange Peel" is slowing down the rate of evaporation of the thinner or reducing the time that the droplets are exposed to the air. This can be done with a "retarder" that is added to the thinner or using a "retarding thinner". Less pressure, more thinner, and holding the nozzle closer to the surface can help. However, the single biggest thing that will make the thinner evaporate more slowly is lower temperatures, either waiting until a seasonal change, using air conditioning, or a more favorable time of the day if there is one at this time of the year.
Eliminating "blush" requires a lower humidity or not compressing the air. The condensation at the nozzle can be eliminated with lower pressures in the compressed air tank, compressing the air and not letting it cool in the tank, or using an HVLP system that doesn't compress the air as much. The condensation on the surface can be controlled by slowing down the evaporation rate of the thinners through the use of retarders. We can sometimes make it go away by spraying a straight thinner on the surface to give the moisture a chance to evaporate.
Lacquer ain't easy, and it can be impossible when the temperature in near 100F and the relative humidity is near 100%. Sometimes the only solution is application with a brush and hoping for the best. Sometimes the only solution is waiting until October; and that is what I did at this time of the year when I lived in North Florida.
More discussion is in the link that will take you to Article-11 of Finishing Secrets here on wood Central.
Lacquer
>Allen I don't clean mine often but do clean it about once a month. I have problems with the hole in the top than lets air in getting clogged. It's easy to clean but I tend to forget that it happens until it won't spray right.
Doug Thompson near Cleveland
>I sprayed a lot Deft with the same HF touch up gun and here's what I found. Use less thinner, more like 70-30. Lower the pressure a bit and spray about 5 inches away from the piece. This will get some flack but use water in the gun and play with the adjustments. Then clean the gun well with thinner.
OR
Go to Jeff Jewett's site and buy a Walcom HVLP touch up gun and have a perfect spray pattern every time. I still use the HF gun for sanding sealer but for the final finish a good gun is worth it.
Spray cans are nice but expensive if you spray alot. A gallon of lacquer lasts a long time.
Allen Neighbors
>John, when I bought my gun, there was a little air line/vinyl tube that connected the cannister lid to the tang. I threw that away, and took a short piece of baling wire (12 guage elect wire works, too), turned a circle on one end for a handle, and stuck the other end in the hole in the lid. I take that out when I start to spray, then put it back when I'm finished. It keeps it from clogging.
The hole will clog occasionally, if I'm spraying a large piece, and turn the gun over. But I just stick the wire plug in and pull it out, and it's clean again.
Allen
>When it is hot and humidity is below 70%, I frequently us a Dupont Thinner that is specifically made for temperatures over 75 degrees. I don't know if is considered a retarding thinner or not, but it does not seem to effect the overall drying time of the applied lacquer. It costs abut $35 a gallon, so I use it only when required, using a good grade of thinner ($18 a gal) most of the time, and saving the "Big Box" brands mostly for cleanup, What Sam Simpson called a "Wash Grade" of thinner.
I also have some Sherwin Williams thinner that specifically is labeled "Retarding Thinner".
I say again, that using a good grade of lacquer and thinner, you will save money in the long run. I have Deft around the shop to spray my shop Cabinets and the like, or when I need a wipe-on and wipe-off application.
Spray cans have their place, but all of them have a very low solids count, and you might save more money by using canned Deft and thinning it, and just wiping it on your work. Some spray cans spray better than others, because of the small spray pattern, they are not suitable for larger work - you really need a 6+" wide spray pattern.
Like I say, just my opinion and experience. I have only been spraying wood for about 3 years, but started spraying cars in my Dad's paint and body shop when I was 14 - and Nitrocelulose lacquer was still the standard finish.
Mark
