A55 Smoothing Plane
Ringmaster Bowl Machine???
Eddie Pacheco, San Jose, Ca.
>Have any of you heard of one of these? I was checking out Craigslist in our area and there is one for sale. I'm not interested in it, but I was curious if anyone here had used one before. Is it an ultra stubby lathe of sorts? Here is the link for a retailer of this thing. The pictures and discription don't give any insight on how the machine is used to create a bowl.
www.woodenpost.com
Re: Ringmaster Bowl Machine???
Re: Ringmaster Bowl Machine???  *LINK*
Peter Teubel
Ringmaster Web Site
Rick Allen
>The device cuts rings at an angle which you glue and stack into a bowl like shape.
The resultant bowl can be mistaken for nothing but a bowl. However the finish tends to include a good deal of tearout.
Unlike woodturning where you are a woodtuner (not a lathe operator) with the ringmaster the best you can hope for is to be a ring master operator.
On the plus side the device is a bit of a marvel. When you inspect the device you shake your head in wonder at the enginering and imagination of the inventor.
>There are a lot of them around here apparently. I see the bowls at various low end craft sales. The bowls always look the same. Same shape, picking woods just for contrast and no apparent rhyme or reason, and medium to poor finishing both sanding and finishing. That being said I know they are having fun making these things and that's a good thing.
I can do the same thing faster and just as clean with a thin parting tool. Also it's easier to change the shape of my vessels because I can instantly change the angle of the parting tool when cutting off the next piece. I can also change the thickness of my rings because I can part in from the outside, something the ringmaster can't do.
Many years a go I made 3 foot tall tornado using this technique. I would cut a groove about 1/2" deep in the center of the outside edge of a 12" disc. Then I rounded these edges quickly and rougly (I wanted the rounded shape but tornadoes aren't smooth) Then I parted through both rings from the flat side until they dropped off. I repeated this procedure many times until the disc was too small to use. 3 mmore of those 12" discs and I had enough wood to build the tornado. I left all the torn grain edges and dyes it black with diluted flat black paint.
Pete in Holland, MI
>My dad bought one of these machines over 15 years ago. Still has it powered by his Shopsmith (which was/is an option). Yes, there are limitations to the creativity of the unit, but he does reasonably good at craft sales with his products. Have helped him along with some of his tooling and such. He'll cut rings for several bowls one day, glue them another, sand the third, then finish on the 4th & 5th day. Normally has no more than an hour of labor per bowl when built this way.
The machine was apparently devised by a shop teacher who was discouraged by kids who paid good money to buy a large plank, saw it up, glue it up, then turn 90% of it into sawdust while creating a bowl out of it. The beauty of it is that a bowl can be created out of a single square plank. A 10" square plank, 3/4" thick, can yield a bowl about 9" diameter and 4-5" deep! Dad buys cheaper knotty planks from his local lumber source and steers around them while looking for his squares.
Yup, it has limitations in manufacture shapes and marketing of the goods, but it does create an acceptable product.
Russ Fairfield
>Does every Ringmaster bowl still have the bolt hole in the bottom that has to be plugged?
These things have been around for at least 30 years that I know of, and they are still a popular demonstration and a good seller at the Woodworking Shows.
Brad Vietje
Too Bad It Doesn't Do THIS *LINK*
Brad Vietje
>I have wondered ... do the results have to be bad ? Can't a person use the ringmaster just to cut the rings, and then do a decent job of finish turning on the lathe ? If more thought & planning went into the woods and the design, could the Ringmaster not be a useful tool ?
Too bad (well, maybe its a good thing) they can't produce work like that of Michael Mode or Stephen Gleasner... I've seen Michael Mode make his incredible stack-laminated bowls (another Vermont guy), and it is some pretty impressive work -- he has to be considered the master of the form.
Safe spinning,
Brad Vietje
Newbury, VT
Michael Mode's Web Site
Mike from St. Clair Shores
>John,
I have had a ringmaster for many years. It has been been gathering dust for just about as many. Although, I would challenge you to make rings with your parting tool as fast as it can. Since I have been turning, the idea of using the ring master along with the lathe has been in the back of my mind. You can create rings of varying thickness. Russ asked if you needed the hole in the bottom. (that's how the wood blank is mounted on the RM) I think if you were able to mount the cutters at lathe center a glue block would work. I used to be able to cut rings for 8 bowls in 1 hour. The cost of the 3/4 in. boards were very reasonable. If a turner made wide enough rings, after the glue up you could have plenty of wall thickness to turn away and create newer shapes. I don't know if any one has done this. If I ever get bored or find some extra time on my hands I just may try it.
MIke
Re: ... and they are always such ugly bowls
Russ Fairfield
>Everyone I have ever seen make a Ringmaster bowl takes great pride in how many they can make in a hour, and they always have that quick and dirty look to them.
There is no reason they can't be chucked and turned on a lathe and sanded to a decent finish, and using something beside a poorly fitting piece of dowel glued in the bottom. For some, reason I have never seen anybody do that. Maybe the reason is that if they are going to that much work, they don't need the Ringmaster.
You can also do the same thing on a bandsaw by tilting the table and using a circle cutting jig. There will be an entry cut to glue together.
Whether using the Ringmaster or the bandsaw, you can cut alternate rings from different pieces of wood so the stacked rings can be varied in width and angle to make something other than a straight sided bowl.
Example...
Peter Teubel
>Here's something I made with the Ringmaster before I learned to turn. Made from a 3/4" Cocobolo rings. 5 1/2" in diameter and 3" tall. The inside is full of chatter marks (gouges?) from when I tried to true it up using a dull spindle gouge (hey, like I said, it was made before I learned to turn!) and the lid has warped a bit. To this day, it sits on my desk holding candy and such.
Thanks, Peter. Informative video.
Thanks, guys.
>The power of the internet... I'll continue to cruise the local Craigslist on the lookout for a wife getting rid of her cheating husband's Oneway 2436..:-)
Re: Too Bad It Doesn't Do THIS
>Brad you beat me to the punch. After reading Russ's answer about using the bandsaw I was trying to look up Micheal Mode's website. There isn't any reason why you couldn't change the angle on the ringmaster it's just harder to do. With the bandsaw it's very easy to do.
At Tenn. Tech where I work our students designed a human powered sub, and they actually won several years ago in competition against the really big guys like Cal Teck and Navy etc. The built the first sub out of wood using a Cheap craftsman bandsaw with tilting head. They ran a computer program on the shape to show the angle to tilt the bandsaw for each cut. Then they just glued it all together and sanded it clean. It was very quick and precise. I thought of this when I saw the wind tunnel. I wish I had a photo but that was pre digital days and I'd have to go to archives to get it.
Re: Example...
Pete in Holland, MI
>The finish on a bowl, being it single point hand turned, or cut with a ring-master, is always up to the one using it.
Yes, you still end up with a plug in the bottom of the bowl, but done right, and using the supplied wood burning rosette, it is fine.
I built my dad an arbor that he mounted outside of his shop to spin sand the bowls, in both directions, and the finish technique he uses makes for a fine looking bowl.
Some of you are beating up this cool little tool. Not everyone has the talents to turn some of the things that show up on this site. Not everyone is interested in jumping into the hobby as deep (time/talent/finances) as some of us. What ever product you make, there will always be critics. If you are in it for the money, and your product sells, be it ugly, rough sawn, poor finish, then your mission is accomplished. If you are in it for the satisfaction of what you can do, and you are satisfied, then that mission is accomplished.
Remember: for all the bowls that are turned and show up on this site, all a bowl really has to do is hold its contents. Period. That is the purpose of a bowl. Beyond that, all the time & fuss we put into them is only for the pure satisfaction of turning and development of our "art".
Barry Turner
>Stubby? No, its more like one of those machines they used to have in stores to cut wooden window shades to length.
Ron McKinley
>Rick's right. There is a lot of tearout on endgrain. I bought one about a year ago just before a friend sold me a lathe for $100. I got hooked on the lathe and never did much with the Ringmaster. It is handy to use up a leftover piece of flatboard to make a bowl.
After I got the lathe I re-turned several bowls I made on the Ringmaster and that solved the tearout problem. There's a group on yahoo that does amazing things with the Ringmaster. They have software that helps you vary the shape and I've seen segmented pieces done on the Ringmaster that looked like they were turned on a lathe......Ron
