OT - Getting a REALLY sharp edge *LINK*
Re: OT - Getting a REALLY sharp edge *LINK*
>So if this process were to become feasible we would simply place the tip of the gouge in some fancy device and it would build up the edge with atoms until it's super sharp. This might take a while so you have two gouges. One you use and other is being sharpened electronically. When the first one gets dull you just change places with the tools. I like this conept. Could we then program it to change the angle?
Don in Central Illinois
>Will this replace my Ellsworth gauge?
cagey59
>And tools would last forever with no grinding required! Would they get longer and have to be ground back after some time?
Rick Davenport
>Or would the sharp edge be so fragile as to be knocked off by wind resistance?
Rick
Thad
>So would a single-atom-edge eliminate the need for sanding?
Jim
>Unless this technology gets much less expensive, we won't see this anytime soon.
Do you know how what equipment and conditions it takes to spray on single layers of atoms?
If you have to ask you can't afford it. This is cutting edge (pun intended) stuff....
Course now, I wonder, if a more crude apparatus might work for building up knife edges. It wouldn't take atoms at a time to do what we need. But it might still be too expensive.
I guess it doesn't hurt to dream tho...
As long as you don't have tool marks :)
Russ Fairfield
>I saw Electron Microscope in the description. That's too expensive for me. Maybe I could get one of those AAW Grants to explore new trechnoloqy.
Steven Antonucci
I had access to a Scanning Electron Microscope...
steve antonucci
>in college. IIRC, the techs who operated it all wore radiation suits and bands that told them when they were done for the month.
Thanks anyhow, I'll stick to sanding.
steve
Craig Daymon
>There are FREE plans for an electron microscope on the internet. I think it is a dutch university. The plans are in english. I think I have a copy somewhere, let me know if you are planning to build one.
-Craig
Don't test this edge with your thumb
Tom Libby
Re: I had access to a Scanning Electron Microscope
>A lot has changed in the years gone by. We have an electron microscope on campus and Ive photographed it many times. There aren't any radiation warnings that I know of. Now talk about a way to see sanding scratches. That would guarantee you don't have any. Of course you have to slice your bowl into little pieces to scan it but you could reassemble it later. It would look a lot like chip board but what the heck.
gary s clarke
>why not get all cutting tools coated with diamonds?
>Gary I read the other day where they can now grow diamonds. So we could just grow our own on the edge. Now that would be cool.
Craig Daymon
>At a cost of about $10/carat and they are PERFECT! No flaws! (Debeer's is very upset.) They grow them just like silicon wafers for the semiconductor industry, which is how some of the companies doing it are intending their diamonds to be used. (They can withstand the heat better than silicon.)
It's an odd thing, but what made diamonds so desireable for jewelry was their ability to bend light and the closer to perfect, the better. Now that man can make diamonds for cheap, the diamond merchants are trying to convince you that a perfect stone is not as good as one dug from the dirt even though it has all the qualities of the best that can be found in nature. As I understand it, diamonds are one of the most common minerals on the planet and it is only the consortiums hoarding them that drives the prices up.
I have an interesting article on the subject in PDF format somewhere. If I could link it, I would. It was originally a web news article.
-Craig
And I thought this would involve honing!
David
Tim Grenville-Cleave
>I'll stick to my Tormek for now I think ...
