latest inside out platter
>This is the latest. I still have some problems to work out. When realigning after the first turning the edges don't match. I am going on the assumption that the wood is flexing during the cut so the leading edge may be thinner than the trailing edge. When I cut the wood apart and then realign them after the 180 degree rotation, the leading edge of one point is aligned with the trailing edge of the other point. Consequently one side is higher than the other. I'm going to use thicker wood or glue some wood on the back of the next one to prove this theory either right or wrong.
Re: latest inside out platter
Did you kill that tigerr
>yourself?
John my first impresion of that piece was that of a tiger skin streched to dry. I am at lost at how you arrive to that texture, Look great
Jorge
Mike from St. Clair Shores
>John,
This way cool also. You sure have been busy turning lately.
I want to experiment with this method some day.
Mike
Re: Did you kill that tigerr
>Wow That's intriguing. I never saw tiger stripes or for that matter Zebra either. I'll keep looking. Might be a piece there. What I do see are ripples on water intercepting each other. I plan to capitalize on that if I have time to keep doing these things.
Dennis in Southern Oregon
>John, how did you shape the outside rim of the platter? Dennis
>Dennis I start out on the bandsaw and then switch to a typhoon cutter in my dremel or flex shaft. Then I follow up with a 1" x3" round sanding drum in the flex shaft.
Brad Vietje
WOW ...I'm at a loss...
Brad Vietje
>OK, John, how in the heck did you do that ? OH, NO, Wait a minute, here... I hate it when people always seem to ask about the technique without first acknowledging the artistic merit... Let's start again:
WOW, John, that is the most interesting turning I have seen in a LONG time ! Its beautiful !! Absolutely gorgeous, in fact !!!
Now... how the heck did you do that ?
Safe spinning,
Brad Vietje
Newbury, VT
Re: WOW ...I'm at a loss...
>Ok Now that you got the question in the right order it's done using the same technique as inside out turning but I did it with flat pieces instead of spindle kind of pieces. Glue together 4 pieces of square wood and turn groove or beads or both. Cut them apart, reverse them 180 degrees and glue them back together (that's the hard part, still have to solve some problems there) Now turn it again. Then turn the backside and then carve the outer rim. It's fun but quite challenging.
Bruce Wiseman
>Yes, I saw the tiger right off. The top conners are the ears, the eyes are at 3 and 9 the nose and mouth at 6. the 3 concentric rings take a little away from the illusion but it is a very awesome piece. Very nice work.
RevDoug
>John, this is a great piece. I was looking over your piece at the symposium and had a guy come by and question what in the world inside-out turned was. I guess I spent 15 minutes with the fellow and I'm not sure I really got the idea across to him. Funny how a simple concept like this can mess with people's mind. You've definately taken inside-out turning to the next level.
Turn 'em round,
>Thanks Revdoug. I'm still working on these things. It's going to take a while to really visualize what I have in mind. I've got to run some more experiments.
