Your favorite bowl finish for saleable bowls ?
Pete in Holland, MI
>Curious to know what is your favorite finish for those of you in the "business" of turning & selling simple bowls ?
Many thanx.........
Pete
Pete in Holland, MI
Many thanx.........
Pete
Re: Your favorite bowl finish for saleable bowls ?
Mike from St. Clair Shores
>Pete,
Isn't there a bowl factory in Holland, MI? I was once on there web site and they sold a product for putting a finish on a bowl. I use Mike Mahoney's Walnut oil.
Mike
Re: Your favorite bowl finish for saleable bowls ? *LINK*
>This may be something that others would also be interested in. This link is to a commercial Bowl Mill. I'm not sure if there are more of these in the U.S. but it is definitely worth the look.
Hard to compete against a factory like this, so I tend to stay away from your everyday salad bowls and try to make more unique ones.
Holland Bowl Mill
Bill Neddow
>I use Behlen's Salad Bowl finish for two reasons. First, I can put a coat onto the sanded bowl with the lathe stopped, wait about 10 seconds, turn on the lathe and burnish the fininsh into the pores of the bowl with a paper towel. The finish I get looks like it has two or three coats, not one. On an 18" bowl, the whole process takes about 3 minutes, and it is dry to touch -- and too dry for dust to stick in it (a problem in most shops. Second, the label on the can reads "Nontoxic, Food Safe Cured Finish". Now, many people claim most oil/varnish mixtures are nontoxic and food safe when cured. I do not challenge this. But that label on the can has sold numerous bowls for me at craft shows and studio tours. Certainly worth the extra few cents a bowl the Behlen finish costs.
Bill Hale / Woodspinner
>I use Hindsman spray on sanding sealer in the spray can. While the bowl is still on the lathe at about 900 rpm spray it on and wipe it off. Let it spinn for a couple more min. and respray and wipe off. It will have a nice gloss.
The Hindsman chemist told me that is a spar varnish with a thinner.
No clean up !
Good luck
Bill in Dolores, CO. ( Back to the cool )
Rick Davenport
>Like Mike, I use Mahoney's walnut oil.
With the bowl still on the lathe -
I wipe it on, let it set for 10 minutes and burnish it in with a paper towel.
Then I wipe on Mahoney's walnut oil/wax mix, let it sit for a half hour and spin that in with a soft cotton cloth.
It gives it a nice satin sheen.
Rick
Can't find the spray
Jack Savona
>Bill, I tried Googling 'Hindsman spray' for the finish you use. Can't find it. Any help you can give me?
Jack Savona
Dick Hines
>Watco
Re: Sorry wrong name
>Hi Jack
Sorry about that but I gave you the wrong name. I use Valspar quick dry varnish sanding sealer. Product # 8065 Valspar Corp..
www.valspar.com
Good turning and be safe
Bill
Re: Can't find the spray
>Jack
I just sent off a quiry to Valspar for info.
Bill
RK in Milw
>You can't beat Velvit Oil. It is food safe and easy to apply. They advertise on this site.
Ron Nelson
