guide rollers
Paul Hammer
>Hello,
I was wondering if any1 out there uses guide rollers on tall vessels (15" or more. I didnt know if it helped on chatter when the vessels gets thin.
guide rollers
Paul Hammer
>Hello,
Re: guide rollers *LINK*
Mike from St. Clair Shores
>Paul,
I use guide rollers (roller blade wheels) mine is made out of steel, But I've seen plenty on the web made out of wood. If you want to check out some photos of mine, here's the site:
http://homepage.mac.com/mfoydel/PhotoAlbum4.html
hope that helps,
Mike
turning jigs and fixtures
Re: guide rollers
Paul Hammer
>That is a very good looking guide Mike. Do u feel it improves the finish on the inside of the vessels?
Re: guide rollers
Allen Neighbors
>This is one that I made to use on vases, etc. It was made for my 12" Lathe, but I'll enlarge one for my new lathe. It works. Rollerblade wheels, also. I thank Bill and Herm for the idea for this one. Can't remember which one, for sure. I've learned a lot from both of them.
Allen
Re: guide rollers
>Definitely! I always bring it out when I'm boring more than 12 inches. I've also had to put it on smaller pieces when the chatter wouldn't stop. I really like it.
Re: guide rollers
eliot
>Check out "The Spin Doctor". He's actually a physician( ENT) who likes to make and market hollowing rigs and steady rests. He makes a hollowing rig with a great looking steady for really big vessels . I have his rig but not the steady. If the steady is made as well as the rig, it will be great. Just click on The Spin Doctor, and it should come up. If not, get back to me and I will dig up his email address.
Re: guide rollers
Lan Brady
>Allen,
I cannot beleive that you painted the Oneway Blue? ha
Great work on the steady rest!
Lan
Re: Blue Oneway.... :o)
Allen Neighbors
>Lan, the color is green, the picture is lousy, and the lathe is a Grizzly. :o) You know I didn't paint the Oneway. :o)
However, I did make the toolrest on the outboard end a hideous streaky yellow color. I wet sanded a Bois d'Arc bowl for about 15 minutes once, before I remembered to spread an old t-shirt over the ways.
I cleaned it up after a couple of busy days, and then waxed it, so it would clean easier later on. :o)
The steady rest does work okay on the Griz, but it's too small for the Oneway. I'm going to change some things when I build the larger one. The base will be 1/2" flat steel, and the riser bolts will be 1/2" dia, instead of 3/8". And I want to build a second lower wheel beam that has the wheels farther apart, to give better support to larger vessels. But with them close together, you can turn smaller diameter vessels.
take care,
Allen
