Shop shot- new tool setup
David
>I bolted an A-frame on the rolling cart and fastened pegboard to the frame. Then I removed the tool rack from the wall and hung it on the cart pegboard. Now the tools are in close proximity when needed or out of the way of flying chips. I will be setting up a new home shop soon, so this arrangement can move to the new location. I also made provisions for storing chucks, vacuum drums, knock-out bars, etc.
Re: Shop shot- new tool setup
Re: Question..
>First - good cart. I like the A-frame design. Good accessibility to tools.
Is it top heavy? It looks like you have a lot of tools hung pretty high. Though the placement of the chucks on the cart would help stabilize it.
Re: Question..
David
>Definitely top heavy. There are a lot of tools up high. I have a big hunk of wood on the bottom shelf that is used for ballast until I can figure what else I can place low to help with the balance. Just need to be careful right now when moving it around.
Paul Porter
A bag of...
Paul Porter
>...concrete mix makes a great ballast.
