Powercrafter Question
Ron in Drums PA
>Is the Powercrafter a self contained unit or do I have to hook it up to my compressor?
Re: Powercrafter Question
>Compressor-driven unless you buy the little compressor they sell for $$ in the "kit" version.
Ron in Drums PA
>All I've found is the "kit version" do you know where I can get the "pen" by itself?
Re: Powercrafter Question  *LINK*
Mike from St. Clair Shores
http://powercrafter.sculptingstudio.com/
Russell L. Babbitt Jr.
>What I have found at Craft Supply and Treeline are kits, but the kits include just minimal accessories. I would consider them to be handpiece only kits. You would still need to purchase or have the regulator/filter assy.
Ron in Drums PA
>Thanks!
What would you consider a good "start up" package
PS *LINK*
>Ron,
If you've made a decision on Powercrafter, fine. But if you haven't considered the Turbo Carver II, you might give it a look. You'll save about $75 (the last time I checked) and its oil-free. I have one and like it for many things. I also use my old Foredom.
The link is to WoodCarver's Supply and you'll find the nav index on the left side under "power carvers"
Wood Carver's
Re: PS
Ron in Drums PA
>Thanks Mark
What's a good set of burrs to start out with?
Re: Burrs
>First you need to note that these hyperspeed deals are realling for fine detail, not for form carving. These speeds require a very light touch or the burr will stall (no torque) and also become glazed with lignin rather quickly. I use a needle point for signing pieces, a small ball for stippling and texturing, a straight barrel for cutting and a granular carbide for etching glass or hard surface. A flame tip is useful for both caligraphy and weighted line work. The selection of 1/16" shaft burrs is pretty limited, although you can get them for free by asking your dentist for his used ones that they otherwise throw away.
What are you planning to do, Ron? If you're going to be removing heavier amounts of wood, a regular flexshaft like the Foredom or Mastercarver may be what you actually want.
M
>Treeline and I am sure others offer the handpiece, and a regulator/filter. The Treeline setup has a on/off valve as part of the regulator. The setup I use has a foot valve. I started out the the Foredom high speed air tool (no longer available) that I think was made by Powercrafter. I have sunce upgraded to the NSK handpiece from Binh Pho. The handpiece is designed for dental labs and is more expensive but I believe it is providing more torque. You get what you pay for. The air turbine is designed for light duty not heavy duty carving. I use my for thin wall piercing.
Powercrafter Kit
Re: Burrs
Ron in Drums PA
>Thanks Marks
From what you say, I may need the Master Carver instead.
