Stihl Chainsaws ROCK!
Dominic Greco in Richboro PA
>Hi everyone,
I figured I'd post something here just as a follow up to my previous post that saked for recomendations for chainsaws.
I finally went and bought a Stihl MS260 with an 18" bar yesterday and FINALLY got to use it today after work. (yeah,...OT on a Saturday. Pretty pathetic, eh?) I managed to make short work of the remaining pile of huge maple logs sitting in my back yard.
I was totally amazed at the power this saw had! Maybe it was becuase I was just so used to getting beat up by my crappy old Homelite. But you could have knocked me over with a feather when that Stihl went through an 18" dia log in less time than it took me to type this paragraph (granted I had to go back and correct my own spelling and grammar twice)
Thanks again for all the advice and recommendations.
See ya around,
Dominic
Re: Stihl Chainsaws ROCK!
Re: Stihl Chainsaw
>Dom,
Don't hold back, now. Tell us how you REALLY feel.
[Thought that would be a good saw for you.]
Dom, I love mine too!!!
Mike from St. Clair Shores
Bill Neddow
>Dom, now you know why Stihl has kept that saw in its lineup of saws for years, and does not "tamper" with it. Everyone I know who tries one loves it.
Kevin Gerstenecker
>I know what you mean Dom............I have been using Stihl Chainsaws for many years, and they are THE workhorse of the Chainsaw breed. I recently had a slight problem with my 026 I thought I would share.........maybe it will help someone should the problem occur with their saw. There is a small, plastic elbow on the Carb. where the fuel line attaches. It cracked, and it would leak out ALL the fuel after it sat for a while. The carburetor is made by Walbro. They manufacture carb's for lot of small engines. The part is not available seperately, and the price of a new carb is $67.00 and change from Stihl. A member of an Arborist Forum helped me out by suggesting and selling me another model of Walbro Carb. for my 026 for $20 less than Stihl wanted. The BEST part of this problem is that the new Walbro Carb. is FULLY adjustable, like the carb. on my 028 Stihl. The factory Carb. on my 026 had only idle adjustment and high speed adjustment. While my newer 026 ran "OK", it never did run as good as my 028. Long story short.........it does now! I swapped out the carb. yesterday morning, warmed up the 026, and dialed 'er in..........idle, low speed adjustment, and high speed adjustment. My 026 has NEVER run this good. It now idles great, no longer has a slight "stumble" when you pour the coals to 'er, and it plain idles, runs, and cuts better than before. Just something to think about for all the Stihl owners. IMO, a fully adjustable carburetor is the only way to go......I don't know why Stihl doesn't use this particular carb on the 026, but they don't. I saved myself $20.00, and have a better running saw.......win-win in my book!
Congratulation on the new saw Dom...........with proper care and feeding, it will last you a LONG time. (My 028 is over 20 years old, and has seen some serious commercial work, and it still goes like a champ!)
Barry Turner
>Amen! I've had a Stihl 361 for about a year now. It works so much better than the big box store stuff I was accustomed to, it is scary.
Homelite/McCulloch/Poulan it ain't. It has loads of power.
Allen Neighbors
>You said it!!
Allen
eliot
>You like Stihl chainsaws? Fine. I despise mine! It NEVER starts. I hate it with a passion! As you know there are four positions, marked O,I and two more marked with some weird symbols. Mine only click into three -- O.I and one of the other odd ones. I set it to the one on the bottom -- one with the odd symbol Yes I have gas in it mixed with the right amount of chainsaw oil. I put my foot on the handle and pull the rope for all I'm worth -- many times until I'm exhausted.Of course, I'm doing something wrong! I'm 67 and will surely get a heart attack from this #@%&* thing! I will calm down and praise you to the skies if you can help me out.
Have you checked the plug?
Ed Moore
>Eliot,
I'm sorry that you have had a bad experience with your Stihl. Have you taken it to the dealer to see what they can do? Of course, if the plug is fouled then it probably won't start. Check that.
Ed
Allen Neighbors
>Eliot,
The bottom position for the switch is the choke. Put it there, and pull the rope through until it coughs once. Stop... if you keep pulling the rope after it coughs, it will flood it, and never start. Put the switch in the next position up.. (you may have to jiggle the throttle and throttle lock to move it up one notch). Pull the rope through again, and again. It should start right up, if the plug is not fouled out.
Hope this helps,
Allen
Keith Tompkins
Keith Tompkins
>Be sure...on most Stihl saws, the choke won't set unless the trigger is pulled in FIRST. then, release the trigger, and start. When started, lift the choke lever. Hope this helps.
Carole Valentine
>My Stihl has the Ezy-start. No jerking...just set the choke (have to squeeze the throttle to set it), one slow easy pull (I can do it with one finger) and she gives a slight cough, move the lever up a notch, one more easy, slow pull and she is off and running. No foot through the handle either. I use Stihl's other recommended way - hold the handle between my knees. Can't remember the model of my saw but I have an 18" bar on it. I love it! I spent too many years trying to give myself a heart attack starting a stubborn saw!
Steve Mushinski
>Old gas is a common problem. Clean the plug put new gas in and see what happens following what the others have said about the switch postions. I have been told gas older than 6-8 months should not be used.
Put stabil in ..
Bob Fawcett
>your gas if you don't run through it that fast. Good for things that may sit a while too like a generator or boat you only run part of the year.
Re: Put stabil in ..
Jim Underwood
>I recently acquired a Stihl chainsaw. Actually traded some cutting labor for it. Went through many tanks of gas and oil, dulled four chains, (broke one!) and turned my bar blue, while burying the full length in a wet 36" Red Oak. Runs like a champ though!
Just wondering what I can do to prevent the chain and bar from smoking when I have the blade in that big a tree? I was told the chains were sharpened before using them, but perhaps not? Also the oiler must be working because I go through a tank of oil at roughly the same rate as the fuel, so it can't be because the oiler doesn't work.
Bill Crommett
>Another thing: If you will use premium gas instead of regular, you will have less trouble with the "old gas" syndrome. The reason, as told to me by a petrolium engineer is the "regular" 87 octane gas is made with "dirty technology" and has lots of different molocules with double bonds that can oxidize into gums.
I use premium gas in my chainsaws, my weed eater, my garden tractor, and all my tillers. The extra expense must cost me an extra $6.00 a year and relieves me of lots of other problems.
Re: Have you checked the plug?
eliot
>You are all so generous with your suggestions; I really appreciate it. I tried almost everything you have suggested with no luck -- won't even cough. The spark plug looks clean as a whistle. What I still haven't tried, though, is new gas, and the gas that's in there is old. I'll try that next. The super quick, easy start attachment appeals to me; can that be added on, or would I have to buy a new saw? I'm at the point where springing for a new one is looking good to me.
Allen Neighbors
>Jim, I would think that the smoking must mean the oil is working. But you might check that you're not tensioning the chain too tight.
I tighten the chain just enough that I leave about 1/8" of slack when I try to lift on the chain at the top of the bar. I've never noticed mine smoking.
Allen
Gary Evans Tallassee, TN
>Hi Jim,
Running a chainsaw with the bar completely sunk in the cut generates a lot of heat, plus the oil seems to be wiped off the chain more rapidly than in a narrower cut. One thing that helps is to pull the bar out of the cut from time to time and rev the saw until you can see oil on the chain. Then you can go back to your cut again. If you are cutting with the chain dry, it will dull in no time flat.
I would imagine that trying to force a dull chain into the cut is why the smoke and bluing occurred. Keep it sharp and keep it wet and you should have fewer problems. It also wouldn't hurt to make a new friend with a bigger saw for those huge logs. 36" is a big piece of wood. I've spent a lot of hours with a chainsaw, but I'd hesitate to tackle a log that size with my 18" MS290.
Gary
Jim Rutten
>My father-in-law has a McCullough and my brother-in-law has a poulan and we bought a little used Stihl off of ebay. We went out cutting cedar trees and long after both of those saws bit the dust my little Stihl was still going. In fact, I gave out before it did and my father-in-law took over on it and sawed some more. STIHL ROCKS.
Ed Karch
>Eliot bring it over and I will tune it for you so it will start easy.
eliot
>Ed,
You are a prince! But guess what? I got it started today and used it to my satisfaction. The problem seems to have been old gasoline. When I took people's advice and put in new premium ( 4 ounces oil to one gallon gasoline) it started up after a few pulls on the rope. I think, too, that my problems in the past can to laid to old gas because I don't use it much and didn't realize that old gasoline can be a problem. I may take you up on your offer anyway to see just how you tune up a chain saw.
Thanks again to all.
Yup...
Peter Teubel
>I recently added an MSE180 to my stable of saws. In the brief time I've used it, its so far above the electrics from the big box stores as to be in the class of small gas powered saws. Very powerful and the chain stops instantly when releasing the trigger. Extremely happy with it.
Fresh gas and A New Spark Plug ? ? ?
Barry Turner
>Unless you have fresh gas and a new spark plug, its not going to start very well. And, I mean really fresh gas! If that doesn't work, take your saw to a Stihl dealer and have him sort things out for you.
