When all else fails, read the directions...
Scott Hurley in N. VA
>I usually like to use a cone-type live center to hold my spindle turning and for safety with large bowls, etc. However, I've had my Jet 1642 for 7 months now, and thought that the live center that came with it only had the cone on it. I've been using a smaller live center because of that. Last night I was looking at a Oneway live center in a catalog, and the comment was made that the cones come off. Having an epiphany, I got out the user's manual and found the sentence that said "Remove or add different tips to the live center by inserting the provided bar through the holes in the..." Behold, the cone screwed right off and revealed a nice new cone center inside. Now I know what the little rod was for. Like they say, you learn something new every day. And there's something to be said for really reading the manual when you get a new tool...
Re: When all else fails, read the directions...
Bob Fawcett
>I have a Oneway that I bought, and I have a black center that came with my Powermatic. They look nearly identical to me. I guess maybe the jet comes with one like my Powermatic has. Don't know if it was made by Oneway, but if it wasn't its a very good copy. Oneway makes several other things that will thread onto the center including adapters for spindle attachments like your chuck and a larger cone.
Brad Vietje
'Nuther Question...
Brad Vietje
>OK, but can the center point be removed ? I thought the skinny little metal rod would be able to push it out -- no ?
Safe spinning,
Brad Vietje
Newbury, VT
>Actually, I was wondering if the thread on the Jet-supplied live center is the same as the Oneway. I could have a use for the large cone attachment.
Scott
Bob Fawcett
>I'll check tonight and see if the Powermatic and Oneway I have are the same thread. Visually, they look the same, but I have never tried the thread parts form one onto the other.
Re: 'Nuther Question...
Bob Fawcett
>On my Powermatic one it can be "knocked out" with the rod supplied, just like the Oneway. This leaves only the ring on both.
Bill Hale
>I have not had the need but I believe you can also reverse the cone
Bill in Dolores,CO
Thanks Scott
Dave Anderson Chester, NH
>Yegads, I've had a Jet 1642 2 hp for about 15 months now and like you never looked at the directions. I'll have to check it out tonite when I get home from work. Thanks for the tip (as it were).
Dennis Y
>Bob, The powermatic and the oneway are interchangable in all ways. I use whichever is handy. Dennis
Another 'Nuther question.
Roger Myers
>So if'n one were going to turn pens, and the pen mandrel says to support it with a 60 degree live center, is that the cone center that you use, or the small hard pin center underneath the cone...or a different center?
Juergen
>The Oneway is a 3/4" x 10. if you buy the appropriate drill and a 3/4" x 10 tap you can make all kind of adaptors for the live center.
Doug Thompson near Cleveland
>Juergen, What a great idea... Aluminum or steel adapters would be easy to make.
I keep the PM center setup with the cone attached and the Oneway with the center pin removed. This covers the turning I do very well.
Thanks for the idea,
Doug
