Try this...
GaryG in MD
>Jen,
There's nothing more frustrating... well few things. ;-)
It would be a good idea to clean all the spyware off your machine, if you don't already do that. There are many free programs (e.g., Ad-aware) that will do this for you.
It sounds to me like you may have a memory problem. I would recommend that you have at least 512Meg of memory (256Meg absolute minimum). If you don't, it's cheap to add more. Lack of sufficient memory is what bogs machines down the most. If you have plenty of memory hardware, make sure you have enough virtual memory established. This is the part of your hard drive that is allocated to the operating system for temporary use when it runs out of physical memory.
You might try deleting all your cookies and starting over with them. I did that once, and it did make a difference. That can happen if you have years' worth of them and haven't cleaned them out.
You might do a Control-Alt-Delete (assuming you're using Windows) and click on the Task Manager button. Then hit the Performance tab and see how much of your memory is in use. If it's more than 30% when you're not doing anything, you've probably got a problem. You can then click the Processes tab to see what program is using all the memory.
There are some other things that Windows experts can tell you, but try these first.
Good luck, Gary
