Gasket material for vacuum chucks
Dick Gerard
>Other than the thick black stuff from OneWay, does anyone out there use something different? I have been playing around with the packing material used for chin, plates, glasses, etc. you get from U-Haul (ala David Lancaster). But you go through that stuff very quickly. Sometimes a single bowl is all you get and then you have to remove all traces of the old material, use spray adhesive on the new, let it get tacky, put it on, clean the edges and the interior and start again. There has to be a better material that is not as expensive as the OneWay black rubber stuff.
