Super Spalted Maple
Super Spalted Maple
Super Spalted Maple
Rick Davenport
>This piece is from the dollar bin at Bow River Woods.
In other woods, a piece they thought to be unturnable.
It's 7"w x 2.5"h x 3/8"thick (more or less)
Light as a feather and rather lumpy from the very hard spots/very soft spots combination (sanding was near impossible).
It was a real adventure turning it since I was never sure if it would hold together.
Sharp tools; light touch.
Finished with spray lacquer since I figured my usual walnut oil would turn up a lot of dark/soft spots.
Comments welcome.
Rick
Re: Super Spalted Maple
Bottom View
Rick Davenport
Brad Vietje
Re: Bottom View
Brad Vietje
>Gee, Rick, I like what you did with that un-turnable chunk of wood ! I think a slightly textured or lumpy surface can work well with spalted woods, and gives an ancient look and feel. Nice save.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Bottom View
Rick Davenport
>Thanks for the nice comments Brad.
My wife tells me to refuse any offers and a friend told me he thinks I used a black marker to get all those lines.
It's definitely a "natural" piece.
Rick
Re: Bottom View
>Rick You certainly did a good job saving it. One suggestion. When you have a torn grain area which happens often with really spalted punky wood, try using a cabinet scraper to clean up these areas. You can cut parallel or slightly askew of the rings and keep the lumpy areas to a minimum or may be able to get rid of them entirely.
cabinet scraper?
Rick Davenport
>John,
Thanks for the advice.
I did a shear cut with a heavy duty scraper before I finish sanded.
The sanding made the lumpiness more pronounced.
Would I use the cabinet scraper while it's on the lathe?
Rick
Re: cabinet scraper? *LINK*
>I think John means a card scraper, instead of a cabinet scraper. (Don't get wound up in the terminology--There is a lot of overlap in current usage.) A cabinet scraper usually means a scraper blade held in a rigid, flat bottomed tool body, e.g., Stanley #80, #85, #12, #112, #212, etc. For more info, reference Patrick Leach's Stanley Blood and Gore.
On the lathe, I use a flexible card scraper, a flat, usually rectangular, hand held sheet of saw steel, with a hook, to very good effect. I usually hold it in both hands, thumbs on top, fingers below, angled downward, and presented to the wood well below center. The tool rest is not used--You need to move it well out of the way.
You also might find it helpful to round off the corners, to minimize the possibility of one of the corners accidentally contacting and digging a groove into the turned surface.
>You are right. Sorry for the terminology mix up. I use a card scraper that looks like a french curve. You can find just the right shape for inside the bowl. I use a flat card scraper on the outside. I don't use these often, just to get rid of really bad spots in woods that have a big difference between the hardness of summer and winter wood. It's also excellent for cleaning up tool marks on segmented turning because it doesn't carry the dark dust into the white woods and sometimes you have the same hardwood, soft wood problems between the segments.
Re: Like this? *LINK*
>Yup, that's the one John uses for insides. It is sometimes called a "gooseneck" scraper, but I prefer to call it a Shmoo Scraper.
Re: Bottom View
david
>Rick:
I think it is also a matter of the degree of change between the thick and thin. I have experienced similar problems working with spalted wood, and have to catch myself and not use hand backed sandpaper, which will conform to the softness versus the harder parts as the piece is spinning. Using a firm backing for the sandpaper such as a block of wood or firm rubber sanding pad helps.
