Turning a table leg leaving a section square
Sam
>I need to turn a table leg, where only part of the blank is turned and the rest is to be left square. I'm not confident about getting clean shoulders on the square section. I'm turning cherry.
Any advice? Thanks!
Re: Turning a table leg leaving a section square
>Sam You can use a spindle gouge or skew, whichever you are the most comfortable with. What I do is mark of the border of the square. Then I start turning about 1" or so from that point. This lets me practice the cut and sneak up on the corner. If you need a rounded transition the spindle gouge is probably the easiers. If you need a really square transiton, meaning sides of the square that are perpendicular to the turning then the toe of the skew is the way to go. If you try to use a parting tool you can easily chip off a corner.
OB OBrien In Pensacola
>Sam; One way of doing it is, where the transition goes from square to round it takes up a little space. Maybe about a quarter inch. So turn it round up to where the transition needs to be. Then use your skew or spindle gouge and gently cut from the square portion, sloping left to right, down hill to where it becomes round. This makes a nice curved transition. Hope this makes sense to you. If not let me know and I'll post a picture. Good luck.
Ken Grunke from SW WI
>Using a sharp skew chisel, on edge, with the long point down is the best way but this takes some practice to avoid a catch. It's mainly a matter of keeping the edge above the point away from the wood only enough to keep that edge from digging in, while still allowing the bevel to be rubbed at the point of cut.
My advice would be to find someone from your local turning club to show you, and to practice on scraps first to become comfortable with what you want to do.
Tools less intimidating than a skew would be a skewchigouge, a spindle gouge, or the lowly cove tool, which I think is a pretty useful tool:
Bob Fawcett
>Here is a link to a video of Ken making the cut.
http://www.turnwood.net/videos.html
It's called a pummel. Here is another video link *LINK*
Don in Northern Arizona
>to Brian Cliffords site in UK.
Don
Cutting a pummel
Dennis Y
>I saw a video somewhere that they used a hand saw to make the square cut. You could also use a table saw to make the cut. You could then round over up to the cut. Dennis
Also called a POMMEL CUT
david
Re: It's called a pummel. Here is another video li
Ruth Niles
>This is a great little video on turning the pummel. Brian has one of the finest websites for tutorials of all sorts and he's an accomplished turning (for years and years!). The method Brian demonstrates is one I use for the steeper pummel cuts. Like John Lucas said, the spindle gouge or bowl gouge work best if you need a curved entry or transition.
>*whacks side of head* Funny, I didn't think of pointing to my videos...
Thanks, Bob.
Russ Fairfield
>Tear-out at the corner can be a problem. Wrapping the piece with a couple layers of nylon strapping tape will hold the wood torgether
Sam
>Thank you for all of responses. It was especially helpful to watch the skew in use in the videos. The idea of letting the bevel ride on the already cut part really opened my eyes. Also, I never thought of rolling the skew as it plunges into the cut. It pays to ask those who know! Thanks again. I'm psyched to do this now! (But I'll practice on some poplar first.)
