THE WOODRAT IS BACK!
Norfolk Pine Bowl
Norfolk Pine Bowl
Norfolk Pine Bowl
david
>This piece is about 8" x 8". Walls are a little less than 1/8". Spalting has just started and the knots/branches are not fully developed. Learned from this piece that you cannot nest the bowls in the soaking solution, as a line developed on the outside that was not able to be removed, even after multiple soaks and partial immersions. Light from above was a partial sun through a skylight.
