ADVERTISE HERE - FREE TRIAL
Lathe bolt down
Lathe bolt down
Lathe bolt down
Bill Hale
>Well I finaly bolted down my Oneway 2436. When I first got it many years back they said do not bolt down. Then later they said bolt it down.
Well now that it is bolted down what a difference. Vibration with a slightly off balance piece is nill. You must use common sence with a large heavly off balance to not damage the bearings,
If you decide to do it I left the factory feet in place and balanced the lathe. I then drilled out one of the 3/8 holes in each lege to accept a 3/8 wedge anchor bolt and drove it in. Pull down against the foot and you are set. You now have the ability to do any up down adjustment.
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Lathe bolt down
Re: Lathe bolt down
Bernie
>Bill I have been thinking about bolting
down my PM 4224 Do you have any rubber
buffers around the bolt or leg?
Bernie
Re: Lathe bolt down
Re: Lathe bolt down
Bill Howatt
>None on my General 26020. The key thing is that the whole lathe is in the same plane so when you tighten down on an uneven floor you do not "twist" the bed. I have read that after time the bed will actually move into the twisted shape. May depend on your bed construction though, mine is cast.
Bill
Re: Lathe bolt down
Re: Lathe bolt down
Vicmarc.fan
>I can see why a Oneway could get a boost from bolting down because it has very little in the way of dampening vibration but with the cast iron in the 4224 I wonder if you would notice any difference. When my Vicmarc first came I thought about bolting but found it didn't need it.
Ron
Re: Lathe bolt down
Re: Lathe bolt down w/ pics
Bill Hale
>As you can see by the pics the Oneway has a down thrust bolt leveling system. Old bold with hex nut lock. First I leveled the lathe and tweeked for good balance controll. Them I used the second bolt that I had installed to pull the lathe down tight against the first bolt. No tweek on the lathe and no consideration for any deviation in top of slab.
Ron As you can see there is no need for any rubber buffering.
Bill As noted above the lathe was leveled first with the lift bolts and then pulled down
Ron I also am a fan of Vickmark. I have a 200 in my Summer shop in Colorado. I do have to say it is also bolted down as it is not very heavy. I used to have it loaded with play sand but got tired of the cleanup hastle.
Getting hot here, almost time to go North or turn on the AC and boy does the power company love that.
Re: Lathe bolt down
Bill Hale
>Dumb Dumb Forgot the PICS
Re: Lathe bolt down
Wow! Slate floor in your shop?
david
>Wish that I had that in mine too ;-).
