A55 Smoothing Plane
Sioux ofset drill help
Bill Hale
>A little help please.
I see many times about work on these by many of you. Mine had the main bearings go out so I got new ones pressed on .
Now my problem is I can not get it back together. The brushes are the problem. Is there a trick or do I just scrap it and go buy another ?
Thanks
Bill in Casa Grande, AZ.
Re: Sioux ofset drill help
Barbara Gill, Remlik VA
>I have not had my drill apart and so do not know how the brushes are in there so this suggestion may not work. If you cut a piece of stiff plastic that you can slide over the brushes as you hold them in and then put the top of the motor on top of the plastic; then you can slide the plastic out and the brushes will be held in place by the motor.
My 12V brush replacement set came with a metal plate designed for this but stiff plastic should work too.
There is a trick
TDaniel
>but I don't know how to explain it in writing. Send it to me and I'll put them back in for you.
TD
Gary Evans Tallassee, TN
>Hi Bill,
Like Barb, I've not had to take my Milwaukee apart yet (knock on wood!) A lot of times the brush holders will have a couple of small holes through the sides. These allow you to retract the brushes, and hold them in place with a piece of stiff wire while you insert the armature.
HTH,
Gary
Re: There is a trick
Bill Hale
>Hey TD
Thanks so much.
Drop me a note and let me know shipping and I will send it.
david
>Hey TD: Can I take you up on that offer too? I will pay for postage both ways and throw in some native Hawaiian wood to boot as an incentive/reward.
sure, but can we wait until after the Gathering?
TDaniel
Brian Hahn in SW Wisconsin
>I just changed the bearings on my Milwaukee this morning. For reassembly, I just lifted the brush holders out of their slots, slid the motor armature in place and seated it, then pressed the brushes against the armature to push the brushes back into the holders enough so the holders would slide back into their slots.
Actually, one of the most time consuming parts of the whole process was finding the right sized Allen wrench for the screws holding the body together.
Sure! Not a problem...
david
