How To Drill HSS?
How To Drill HSS?
How To Drill HSS?
George Van in WI
>Is it possible to drill HSS? I have some 1/8" thick that I would like to make into bits for a hollowing tool. The bit I tried did not penetrate. Maybe I need a different angle on the bit or a method to heat the spot. On thinner metal scrapers I was able to spin a nail head creating a hot friction spot to loose the temper and drill without loosing the overall temper of the piece.
Re: How To Drill HSS?
Bart Rhoads
>This takes a special type of drill bit. Solid carbide I think will work. I use a special bit called a Bad Dog Bit. I purchased them at a woodturning symposium. I have seen them a woodworking shows also. You can drill holes in files and even taps.
>There's also a drill bit made by a company called ARTU. The run at very high speed and don't start drilling until the bit gets red hot. It's bizarre but it works. I bought mine at the hardware store but they only carried them for about 3 months.
Karl in IA
>I have used a drill from Rodman & Co. Phone 800-228-1806. They may be the same as the Bad Dog. I got mine at the State Fair. They say to drill at 2000 rpm minimum.
Dick Hines
Dick Hines
>I use a good grade high speed twist bit. I drill real slow and use 3in1 oil onthe bit to keep the heat down.
George Van in WI
>Thanks all for the suggestions.
Bart, I will check Google for bad dog. I can�t imagine what else besides drill bits will come up!
John, I will do the same with Artu.
Karl, I will check with Rodman, they may be different than Bad Dog.
Dick, I will buy a new bit, not a cheapie, and give it one more try using your method.
Ken Grunke from SW WI
>George, I've used a glass drilling bit with success, the kind found at most hardware stores. Don't push it hard, take it slow.
here they are *LINK*
>My morning client is late so I looked up the bits for you.
http://www.artu.com/drillbits.htm
George Van in WI
>Thanks Ken, I never thought of try that, I think I have one in the shop, if so I will try that.
Thanks John
George Van in WI
RussFairfield
>Why don't you make life easier for yourself and make the hollowing tools out of a carbon steel? It can be about the same hardness as an M-2 HSS with a lot less effort.
Drilling HSS can be done a lot of ways in theory and according to the advertisements. Some HSS can be drilled with a carbide masonry bit running at a slow speed and using a lot of oil as a coolant. Your "hot nail" method can be used to destroy the hardness in a local spot, but you will also risk altering the metalurgy in the rest of the bit. The "hot drill" has the same problem.
My experience with all of these methods is that we will reduce the HSS to no better than a hardened carbon steel, and sometimes not as good; and we will have wasted a lot of effort doing that.
A better solution is to use a hot saw to make a slot from the enge to the center of the bit.
To use a carbon tool steel, do the drawing and hardening steps, but omit the tempering.
It can be annealed by heating to Cherry Red and allowed to cool in still air. That makes them easy to drill and grind to any shape you want.
Then heat them to the same Cherry Red and quench in oil or water to reach maximum hardness. Omit the drawing back. The steel will be brittle, but that is OK for a hollowing tool bit that is supported in a holder.
Gary Evans Tallassee, TN
>Hi George,
You might try cobalt bits. They are available at the box stores. We used to use them to drill Stainless Steel in the elevator business.
Gary
Phil Powell
>George,
I saw Bad Dog Tools at the Milwaukee Wood Workers Show. The drill bits are
amazing! They are on the net at baddogtools.com
See ya soon.
George Van in WI
>Thanks Russ, I will try your method when I get the opportunity to get some good carbon steel. It sounds similar to the method we used when our group made hook tools following Al Lacer�s directions. I only have the HSS at this time. I found I was grinding away my scrapers changing the profile for special situations and thought the use of bits would save the tools and add versatility with the replaceable tips.
George Van in WI
>Thanks Gary, the ARTU bits are Cobalt and Tungsten Carbide, the nearest box store is 75 miles, I may have to go for thinset for the tiling project I am doing, if so I will check at that time.
George Van in WI
>Hi Phil, I am using the HSS blades that Dale brought to the meeting. I will let you know how this works out. The Bad Dog bits have a lifetime guarantee, which is nice. If you had bought one when at the Milwaukee show I would not have to ;-) Hope you can make the next meeting. Let me know when you are up; maybe we can get together at my shop or yours.
>Russ has a point that I forgot about. After buying the bit and drilling holes in my hss pieces I read about just cutting slots using an abrasive wheel in an angle grinder. I did that and like it much better. You don't have to pull the screw completely out of your boring bar if you need to sharpen the bit. Just loosen it and it pops out. The only downside is you can't use all sides of the bit for cutting. This isn't a big deal on most bits. I have a round bit that I use some and I like to just rotate it and use it some more. I can use it a lot before sharpening.
Prefer my 3/16" HSS square bits for most of my hollowing now. I only use the larger cutters if I'm doing a vase or really open vesse. Then I'll use those to finish the sides.
George Van in WI
>John, I use the Scorpion, Stinger, or Kelton for most hollowing. Vases and enclosed bowls are the two areas I use the scraper, to minimize sanding by removing the tool marks and sharpening often to eliminate chatter or tearing. I am going to try my r/a grinder with a thin blade tonight to try Russ� slot method. If it works that simple it would simplify things and it would be easier to have an assortment of profiles.
Rick in Colgate, Wi
>The bad dog drill should work George, but you may need to buy a whole set to get the size you need. You may also try a titanium nitrite coated drill, very hard wear surface. We used to use them for drilling holes in drill rod.
George Van in WI
>Thanks Rick, I do have to drill holes in drill rod also so it would not be wasted!
Steve Worcester
>Carbide or cobalt drills will work. Glass drills probably also as they are usually diamond or diamond impregnated.
If the bit gets red hot, you are usually going to get that spot hot and when it cools, it is harder than you started (like case hardening). If you get the material red hot, it may anneal, but you would have to get the entire part red hot before you loose the hardness all the way to the edges.
I don't recommend getting it red hot and annealing. HSS (M2) needs about 2200 degrees to reharden. And a more controlled atmosphere to go through the entire process. If you anneal, drill and then cherry red into oil (olive oil works well) then heat to about 400 in an oven for an hour and allow to cool with the oven to air temp, you can get pretty close for small scrapers and what we do with them.
Most of these reasons are why it is easier to use O1 tool steel. It won't keep an edge as long, but it is really temperature tollerant of the whole hardening/tempering phase.
Do not try to anneal S7 though. If heated cherry red, it gets super hard.
Steve Worcester
www.turningwood.com
George Van in WI
>Thanks Steve, you gave me a better understanding of what I have to consider.
Bob Fawcett
>Could you clamp the cutter in place without a hole in the cutter? If the support and clamp are made of less hard steel you could work it easier.
George Van in WI
>Might be a good idea Bob, my concern would be that the bit might be able to vibrate loose and become a projectile. I guess that with a collet type hold that would not be a concern. Maybe a drop of CA glue then pinching would work? I have not silver soldered but when John describes the method it seems within my reach. I would consider silver soldering a bit to a rod and de-solder when the bit is ground away. I do not know if 50/50 solder would work or not?
Re: here they are
Wayne Kuhn
>I believe these used to be bad dog bits. I have used them numerous time for masonry (cuts like buttah.) But not for HS Steel. There demo at the WW show is very impressive. According to the demo they cut just about anything.
