Anyone make a hollow headstock extender?
David
>I got a headstock extender to reverse deeper bowls, but it cannot be used with my vacuum system. I have some home-made vacuum chucks that should do the job, but I like to use the Oneway vacuum cylinders because they are so well made. Have a hunch that if available the price will be steep, but as someone recently said, woodturning aint cheap!
Re: Anyone make a hollow headstock extender?
Gary in Zirconia, NC
>Just drill a hole through the extender you have.
Jerry Whitaker
>Should not have to be very big. I would think 1/4 in would be more than enough....even 1/8 in. would probably do. You can put a lot of air through a small hole real fast. Others may have opinions on this.
Re: Anyone make a hollow headstock extender? *LINK*
Gordon Seto
>I ordered mine at the Best Wood Tools booth. It was hollow and nicely made.
It doesn't mention that the extender is hollow in their web site; probably they may have two versions.
3" SPINDLE EXTENDERS
SX3-XX
Gordon
http://www.bestwoodtools.com/
>I would look at drilling but if that's not an option I would have a machinist make an extender that screws on the outside of the spindle, has threads for your chuck on the other end and center drilled.
Thanks, guys! Too chicken to drill a hole
David
>in the extender I have even though it is made from aluminum. Taking it to a machinist to drill the hole would probably cost as much as getting a new one. Will check out the one recommended from Best Tools.
