We value your privacy.
>I am considering the purchase of a small narrow belt sander such as a Proxxon or Makita. It doesn't have to hog material, but I don't need a toy either.
I would appreciate knowing your opinions and experiences with such devices. Recommendations welcomed.
>I had a Delta 1" X 30" that did all I wanted till I found an old Belsaw 1" X 42" that had a deeper throat so I traded my Delta for it. Never looked back. But I would buy another Delta if I needed a new one.
>Ed I assume your looking at small handheld strip sanders in the 1/2" size. I am looking at air powered. They run from $49 to almost $600. I have played with the Grizzly, I think it was about $79. It's pretty flimsy and so are the HF and Northern tools versions. However Ithink they would do for awhile. If I was going to do very much of that kind of work I would look at the really good ones like Dynabrade.
I don't have any experience with the electric ones.
>David Air powered sander eat up more air than anything else. I definitely need a bigger compressor. However I've found that most sanding jobs don't take that long and I let my compressor cool down after those projects.
>George beat me to it. I use the dremel or flex shaft to shape the legs and then use a small drum sander to clean them up. I got a 3/4" drum sander from somewhere but darned if I can remember this morning. I also have a 1"x 3 that I use a lot. They have a 1/4" shank so I had to buy a different handle for my flex shaft to handle that size. These are really great for shaping and clean up of all kinds of shapes.
I also bought some 1" disc sanders. The are really good for cleaning up larger concave areas that the drum won't get into.
If you use the nose of the 1/2" strip sanders it's very hard to control and will gouge the work if you don't keep it really flat. the long side works great.
