Help with morse taper slipping
Bruce
>I am having a problem with the taper slipping on my chuck as well as my buffing system. I have tried to gently tap the chuck in but it seems to begin slipping rather easily. I have cleaned the inside of the spindle and the tapers with no luck. This never seemed to be a problem on my jet mini but it has been a challenge on the new powermatic. I hope my terminology is close enough for you to understand my problem.
By the way, this is an awesome group of folks with more talent than should be allowed.
Thanks,
Bruce
Re: Help with morse taper slipping
Leo Van Der Loo
Re: Help with morse taper slipping *LINK*
Leo Van Der Loo
>Hi Bruce
Maybe the MT in your spindle is not cleaned out properly, here's a link to a cleaner that is also handy to have around, just make sure that the MT is not damaged.
If it is you will have to have it repaired first.
Have fun and take care
Leo Van Der Loo
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=890-562&LARGEVIEW=ON
Bruce
>Thank you for the response. I will give this a try.
Bruce
Cleaning male and female parts
David
>of any lubricant or greasy anti-rust or corrosion measures may help. Mine slipped too until I gave it a good cleaning with some solvent. Don't remember what it was, but is a problem no more.
Steve in NC
>Besure it is not bottoming out. This can be a problem on self ejecting tailstocks.
This works for me
Jack Savona
>I don't have issues with my chuck slipping because it's threaded on the tailstock. Can't quite imagine the need for a morse taper on a chuck except for a Jacob's chuck.
However I used to have a major problem with the morse taper on my buffing wheel wanting to work itself out. My solution was to get a threaded bar to fit into the inside of the morse taper (mine had female threads...not sure of the size). This bar was cut to protrude a few inches from the left of the tailstock. A wide washer and a wing nut hold it securely. Eventually I turned a handle for the bar so I could use it as a tommy bar to eject the taper.
Hope this helps.
Jack
Re: This works for me
Bob Fawcett
>I have a pen mandrel with a morse taper to mount into the headstock. When I got it, it would slip. The taper was machined and not completely smooth. It still had machine marks like a micro thread that was proud of the taper. This made it slip in the headstock. I had to polish the machining with very fine sandpaper to get a proper fit. If yours is like this, use silicon carbide paper (wet/dry paper sold for auto body work) to smooth the machineing. Sand longways along the taper and rotate the taper as you sand to make sure you sand evenly all around it.
It was a pitb, but now the taper seats properly and no longer slips.
Re: Powermatic has had taper problems in the past.
Al Crandall (NE of Indy)
>Locally, I personally know of two tailstock spindles which had to be replaced when new because the morse taper was bell mouthed and the taper shanks were only mating with a very short area in the back of the spindle. Both men had their spindles replaced by Powermatic with no hassle.
To check yours, insert a taper shank which you know to be true into the taper socket. Seat it using only an ounce or two of pressure, and then wiggle it around to see if there is any movement. There should be absolutely none. If you can get access to Dykem Layout Ink, you could paint the shank with the ink and twist it in the socket to see if it wore rings off the ink in a uniform pattern.
Bill Howatt
>Devices mounted via a Morse taper in a headstock that do not have pressure exerted on them such that it tries to drive the taper back into the headstock will loosen sooner or later. Often it is sooner.
Device like a Jacobs chuck on a Morse taper (that will be used without pressure like it gets when drilling in a tailstock) and the taper on the Beal buffing wheel mandrel should have a threaded draw bar attached to them with a nut and washer holding them tight into the spindle taper. You can buy pre-threaded Morse tapers for this purpose. If yours aren't threaded you might be able to thread it, usually 1/4-20 or so, but it may be too hard. Just depends on how it was made.
bill
Bruce
>Thanks to all who have given thought to my question and taken the time to respond. I will try out your suggestions and let you know what I find. Thanks again!!
Bruce
