Will this hurt anything?
Carole Valentine
>Found a chunk of lead in this piece of English Walnut. Not sure if I should dig it out or leave it in there and try to make it a part of the turning. If I can do that, I think it would look pretty neat! It won't hurt my tools will it? It's very soft (non-ferrous)
Re: Will this hurt anything?
>Carole It won't hurt your tools at all. Just use a mask or dust collection when sanding, you don't want to breath that stuff. You can actually turn aluminum, brass and copper with HSS woodturning tools. Softer metals like pewter and lead you can turn with just about any tools.
David Breth
>And be mighty sure it is in that wood BUT GOOD. Nobody wants hot lead flying aroung the shop.
Amazing color on that piece!
david
georgetroy
>Go for it Carole, for a person of your ability anything is possible. That is a nice looking piece of wood. When you bring it to round it looks like you can lose your lead. GT
Carole Valentine
>Yeah, Geroge, I think that is what is going to happen. But I'll try. I'm going to try and probe to see how deep it goes...don't want it to come flying out accidentally.
Ron in Drums PA
>I have a few walnut boards with lead buck shot embeded in them. I thought I ruined my planner blades when I saw that shinny metal, but it didn't hurt them at all.
Just apply some CA glue so the lead doesn't come flying out at you.
Dick Hines
Dick Hines
>If it is lead it will not hurt anything to leave it there unless you are goinh to use the piece for food.
Keith Tompkins
Keith Tompkins
>Hi Carole, I hit two nails on the same piece...only minor damage to the tool, cut the nails cleanly! Packard 2030 gouge only needed minor resharpening.
I cut a lot of walnut in California
Don Henthorn
>and regularly found lead bullets in the bowls I turned. Just once did I get one that came out perfectly. The bulley was located so that its perfect outline showed on both the inside and outside of the bowl. Should have kept it as a converdation piece, but gave it away many years ago.
Is It A Bullet?
Barry Turner
>Your piece of lead may be a bullet. A friend of mine, Ray Sandusky, turned a maple ginger jar with a Civil War era bullet firmly embedded in the side. Makes a wonderful conversation piece. He lives near Franklin, TN where a number of Civil War battles were fought. The tree came from near there. You can see it at www.artisticwoods.com
Re: Is It A Bullet?
Carole Valentine
>Yep. Dug it out and it looks like a 22 long. Dug 3 more out of the inside of that one piece of wood. Obviously someone had used the tree for target practice.
Re: Is It A Bullet?
n2wood
>Carole have you ever heard of squirrel hunting? Walnut & oak trees are a good place to look for bullets from hunters. I think it must be something about the nuts and acorns ;{)
Re: Is It A Bullet?
Barry Turner
>As I recall, my friend's maple tree had a Civil War Minie Ball embedded.....doubt it was target practice......just a bullet that missed it's mark.........
