We value your privacy.
>Hoping to improve my meager photo taking skills. While I am aware of the depth-of-field ramifications of a stopped down lens, on my digital camera I get lazy and forego the manual settings and use the auto focus, auto exposure settings. My question is: In the automatic mode, which setting gets more depth-of-field, assuming constant light levels: 1) Setting up a distance from my turning and using the zoom capabilities of the camera to fill the viewfinder, or 2) With no magnification, bring the camera physically closer to the object until the viewfinder is similarly framed and filled? I hope the answer isn't "It depends". Come to think of it, how about just increasing the light level?
>David shooting at the wide setting or zooming in will give you exactly the same depth of field if the object you are shooting is the same size. But,(here it goes)it depends. On the auto setting the camera may actually change the f stop. Assuming the f stop stays the same you will get the same depth of field.
Increasing the light level may or may not change the f stop in Program mode. It might decide to change the shutter speed instead. If you have an Aperture priority mode you could pick the aperture and then the camera would definitely change the shutter speed and not the f stop.
Changing from wide angle to narrow angle(or zooming) only changed the compression or appearance of foreshortening, and the angle that you see behind the subject.
>...are all related, and they're all related to zooming, too. If you look at any zoom lens, you will see some numbers expressing the maximum aperture as a range, e.g., 1:2.8 - 3.7. That's because, at the telephoto end of your zoom's focal length range the effective aperture is smaller. I'm not sure whether this has to do with a physically smaller iris size (doubtful in a digital camera) or just a reduced light gathering capability at the top of your focal range. A smaller aperture gives more depth of field than a larger one, but a one-stop difference in aperture at the wide-open end of the scale isn't going to be noticeable.
If you would like to increase your depth of field, you can increase the sensitivity of your camera by changing the ISO setting, or you can increase the amount of light on the subject. In general, higher ISO settings are "noisier" (or "grainier," if you're using film), so lighting control is probably the best bet. Then you can select the aperture that gives you exactly the depth of field you want. If you camera has an aperture-preferred setting, use this to fix the aperture at your preferred DOF; the camera will adjust the shutter speed accordingly.
>Good point Ellis. After I finished that I realized that I had forgotten variable aperture zooms. Some have as much as a 2 stop difference between minimum and mazimum zoom range. That's a really big change.
One other option to get more depth of field is to simply back away so the piece is smaller. Then you can crop it later. On low res cameras this won't be a very good option because it will suffer the dreaded pixel disease.
>... to say that a smaller aperture gives MORE depth of field rather than less, but most of this thread has been right on. Having more light will cure many ills, and selective manual focusing will cure the remainder!
