Finish help please
Finish help please
Finish help please
ken chase
>My jakaranda hollowform project had some fine cracks so I coated the whole piece with CLA glue. Will this cause any problems if I choose to finish the piece with either Deft laquer or tung oil? I can still see cracks and will have to touch up with a liner brush and either colored ink or acrylic paint. Unless there is a better way I don't know about.
Thanks
Re: Finish help please
Mike Schwing from Md.
>Ken, tung oil won't sink in evenly/well after a piece is sealed/treated with CA. (you said "CLA" but I assume you meant what we commonly refer to as CA). True tung oil is a penetrating finish that can show some build quality with enough coats. Wally uses Daly's tung oil finish and he gets a nice build out of it but it is primarily a "in the wood" finish. Waterlox also builds nicely due to additional resins.
BUT - after using CA on a piece I would not choose an oil based finish, if it were me. Lacquer or another film type of finish should work just fine. Test first on an inconspicuous area (like on the bottom for example) to make sure it is chemically compatible with the CA, but you should be OK.
Ken, I have had good luck with oil if....
T Daniel
>I sand the oil in. Sanding the oil in usually gets rid of the blotch caused by the CA.
Not an expert, but I think
david
>that what TD is essentially doing is removing the CA penetrated areas of the wood. The lack of oil penetration indicates the area sealed up by the CA glue. Remove that, then the oil will penetrate. On some woods, the CA will pretty much sit on the surface. One others, it will penetrate deeply.
