What kind of disposable gloves do you use?
David
>I am soaking a bowl that I made from a beautiful piece of spalted maple that I got from Chris Keuhn. The solution is basically Watco oil, and very soon after I started sanding with wet/dry sandpaper, my latex gloves started to disintegrate. In no time they were useless! I had just purchased a box from my local drugstore. I know disposable gloves are also made from materials other than latex--are these readily available? Are there other options available that are relatively inexpensive?
Re: What kind of disposable gloves do you use?
Re: Nitrile!
>Nitrile gloves are more solvent, oil, etc. resistant. I have a box of the disposable. I also have a pair of longer non-disposable nitrile gloves that I often use.
Re: What kind of disposable gloves do you use? *LINK*
Rick Allen
>Latex, Vinyl and Nitrile are the popular forms of disposable gloves. They all cost about the same, about $7 a box (sometimes you can find them for $5 a box).
I like the Nitrile gloves because of the stretch. I find I can use them as many as 10 times depending on the finish. Nitrile doesn't respond well to acetone. There may be some other solvents which also destroy nitrile gloves. Latex gloves don't respond well to some other solvents and Vinyl gloves (which have the least stretch, bad fit) have particular strengths which make having some of them around a good idea.
All this to say that you should add a box of Nitrile and a box of vinyl gloves to your safety gear. You will likely find that you like one type better than the others but you will also find that each material has it's place in protecting you from the bad stuff.
I am including a link to a source for these gloves. There are many many sources. The last box I got was from a different source.
Link to cheap source of disposable gloves
Chip Peterson
>If you have a Harbor Freight store near you, you can get Nitrile and/or latex on sale frequently.
Harbor Freight Nitrile gloves
Phil Joines
>I've had that happen when using leather dye. How about blue hands?
Thanks for the help guys!
david
Nitrile Gloves and CA Glue
Jake Niedling
>I have found that the blue nitrile gloves are excellent when using CA glue. The glue will not disolve the glove.
