Something is bugging me............
Rick Davenport
>On my first visit to the Seattle chapter of the AAW, I won the raffle and got to bring home a big (24x30x12), beautiful cherry burl.
It was harvested a month or two ago and the cut side was anchorsealed.
It's sitting in my shop waiting for a bigger lathe (which landed is Seattle today!).
I just looked at it this morning and there are 5 or 6 little piles of bark dust on the shelf under the burl.
Somebody is eating my burl!!!!
So what do I do?
Get some surplus agent orange and soak it?
Let the buggers munch?
Your advice please and thank you.
Rick
Re: Something is bugging me............
Molly Winton
>Probably powder post beetles Rick. Isolate it so they don't spread to your other wood. Microwave can kill 'em, possibly soaking in alcohol if you've got a lot. But as I recall that is a pretty big chunk of wood. Could just put it in a bag and let them munch. The holes can be an interesting feature in a turning. Course, I can just take the messy thing off your hands at no charge.
Don Tewell
>A fellow turner, here in Central Illinois, had the same problem. He sprayed with bug killer (Black Flag or something similar) and then bagged it in plastic for a week or so. Every few days, he would open it up and spray some more in. It took a little while but got rid of them.
My Guess is....
W.C. Turner
>wood borers. I've seen these piles of dust also in my woodpile. I had local extension service check them out, & wood borers was their determination.
Cody Carse
>Put it in a bag with some bleach and seal the bag good and tight. That should kill the lil boogers.
Caution: Bleach will...........bleach!
david
Allen Neighbors
>Rick, I use a syringe on those little buggers. I put lacquer thinner in the syringe, and squirt a couple of cc's into each hole. If there are a lot of holes, it may take some time, but it does the trick.
Hope this helps.
Allen
Gary Evans Tallassee, TN
>Hi Rick,
A mineral spirits bath should take care of your problem.
Gary
Re: Something is bugging me............ *LINK*
JKJ in East TN
>If they are tiny holes in end grain (and burl can be all end grain!) they may be powder post beetles. If larger and in the bark they may be something else.
If they are power post beetles, the experts on the sawing and drying forums state that nothing you can put on the outside is likly to work. The problem is the bugs are likely deep in side the wood, far from the surface. Worse, eggs deep in the wood may be harder to kill than the beetles. The holes are often packed tight with frass which keeps any chemical from moving far down the hole. If you see piles of fine frass, those bugs are right near the surface and you can probably kill those, but not those deep in the wood and not the eggs. The only thing I've seen recommended is heating the wood until it is over 130 F. This is what the kiln operators do, however they almost never work with wood thicker than 2". It may be difficult to get a thick turning blank that hot and the heat may cause damage. These bugs can evidently live stay in the wood for a while - I read the eggs can take 2 years to hatch. (But on the bright side, the little holes can be quite decorative!)
Note that when the beetles exit the holes, they are looking for love and some new end grain to chomp into, so watch out for your other wood.
Note that there are two different types of common powderpost beetles. Check the link below for a good note by Dr Gene Wengert (at the bottom of the discussion there.) A search will return other such links.
If the bugs are instead the bigger ones who live in live bark, the chemicals should work fine, or strip off the bark. My experience is these guys don't live long anyway.
note from Woodweb
Re: Another suggestion... (Long)
Allen Neighbors
>Rick, I brought some antique clocks back to America with me from Germany, and a shadow box that I had made from an Army Ammunition Box. The shadow box and a couple of the clocks had some tiny worms that I killed with the syringe... about 2 hours on the clocks...
Also, a friend of mine taught me this trick with the borers that infest Ash, Chinaberry, and Mesquite (here in this part of the country): Place the wood inside a cardboard container with a couple of "no-pest strips", and seal it shut with tape. The larva hatch into black & white spotted, "flitty" insects, that resemble a Yellow Jacket wasp (except for the color, of course). The "no-pest strip" kills the insect, before it can lay more eggs.
Now, this worked for me for years when I was making bandsaw boxes, because I would store the wood in the carton for a couple of years while it cured out.
I know that you can't purchase the insect strip anymore, but if you could google a search, and find out what was in it, you might be able to purchase something close, chemically.
Now, I use the Lacquer Thinner/Syringe method. It stops them cold. I don't know if the thinner penetrates the frass, or if the fumes penetrates the frass, but I know it works. After injecting the thinner, I set the wood aside, and check to see if I missed any holes in a few days... if I see anymore sawdust, I inject it again... but that's not often.
Hope this helps you some...
Allen
Pat Mulligan
>Use it quick and soak the roughed out workpieces in alcohol.
Karl in IA
>I use a "space bag" they advertise on TV. Put the wood in, dump in about a cup of alcohol, and seal. Then evacuate the bag with a shop-vac. This leaves an atmosphere of mostly alcohol vapors. Seems to work.
