Coloring Epoxy?
Coloring Epoxy?
Coloring Epoxy?
Mike in Fort Walton Beach, FL
>I am considering experimenting with coloring epoxy based on what I saw in the book "Decorating Turned Wood". The book says to use powdered color but I'm having some trouble finding it. So what are my options? I have seen powdered dye that might work. Liquid paint is always an option but I wonder if it will cause problems with the epoxy curing. I think I have seen powdered tempra (sp?) paint. I guess I'm just looking for a little more guidance than the book offers. I don't want to sand my colored epoxy and have the colored dust stain the rest of the turning. I have checked at Jo-Ann fabric and crafts and my friendly neighborhood Wal-Mart with no luck on the powdered paint so I have to try and remember where I saw them. Thanks in advance for help and guidance as usual. Oh yeah, coloring with coffee and powdered graphite would probalby work but again, how to keep the powder from staining the adjacent wood when sanding. I would think the graphite would be like rubbing a pencil everywhere you sand.
Mike
Re: Coloring Epoxy?
Re: Coloring Epoxy? *LINK*
Dennis Taylor
>I have turned some platters, with a color epoxy filler...I use the epoxy from pat catan's, craft store, and you can color it with ink, I buy the ink in a bottle with small eye dropper cap, and just need to add a drop or two....the transTint dye from Woodcraft seemed to work nice, but it is expensive....make sure you spray the item with lacquer to prevent the color from bleeding into the area's you don't want color, and it will bleed if you don't seal the wood...trying following the link, this is a step by step from a fellow turner at a local meeting...
http://www.ncwt.org/tips/BeckerEpoxyDemo/page1.html
the link should help yo out...this is the way I do mine also...if the link don't work let me know
http://http://www.ncwt.org/tips/BeckerEpoxyDemo/page1.html
Re: Coloring Epoxy?
Re: Coloring Epoxy?
Jill
>Mike, I found some pigments at the local artist store. I also found some colored pigments at a Hobby Lobby. I have not tried either just yet but I was told by an experienced turner both of these would work with System Three epoxy. I did mix some acrylic artist color w/ epoxy and gave it a couple of days to dry. It is dried but I havent been successful at sanding it. I have only gone up to 400 grit; something tells me I need to use higher grits. Good luck and let us know how things work out.
Re: Coloring Epoxy?
Re: Coloring Epoxy?
Ken Oakley-Sunny St. Cloud, Fla.
>I have had good sucess using Aniline dye powder puchased from Woodworkers supply. (Woodworker.Com.)
I use the powder dry and mix it in with the Epoxy.
Re: Coloring Epoxy?
Re: Coloring Epoxy?
>Thanks for the responses so far. The nearest Hobby Lobby is about an hour away but I might make it out there next week-end. The link didn't work as typed but I just let it open in it's own window and remove the extra "http". I was worried about adding liquid paint because the epoxy we use at work won't cure if there is any alcohol in it. The link was pretty informative though. And I never did think about the color bleeding.
Mike
Re: Coloring Epoxy?
Richard Allen
Re: Coloring Epoxy?
Richard Allen
>There are loads of ways to color epoxy. The key steps I look for are:
"wet" the joint. This means that you apply a coat of epoxy on all the wood surfaces that you will be putting the color epoxy to. This "weting" procedure will form a barier to the color. You will also get a an execlent bond between the wood and the colored epoxy.
Add some filler to the epoxy before you add the color. The filler will do two things. First the filler will make the epoxy opaque which will let the color added be more vibrant. Second the filler will help prevent the color from migrating into the wood.
Heat the wood before "weting". The epoxy will soak in better that way and reduce the bubbles.
Vibrate the wood (a random orbis sand works well) to bring bubbles to the top. Prick the bubbles with a pin for about 15 minutes or until you can't detect any more bubbles.
Color can be found from many different places. The inlay of color isn't a structural so the quality of the cure isn't critical.
Good Luck
Richrd
Re: Coloring Epoxy?
Re: Coloring Epoxy?
>Richard had some good tips. I use tempera paint powder, ground up pastel chalk, India ink and Analine dye most often. You do need to sand higher than 400 grit. I usually sand to 600 and then use 4/0 steel wool.
Re: Coloring Epoxy?
Re: Coloring Epoxy?
Mike from St. Clair Shores
>Mike,
This sounds a little crazy, but I read that some turners used instant coffee as a color. Well I needed a brown for an epoxy repair but didn't have any instant coffee so as I was looking around the kitchen cupboard I saw a can of Hersheys powdered cocoa. I experimented with it and got the color I needed and it worked great.
Mike
