What's your "trouble spot"?
Carole Valentine
>Mine always seems to be the widest part of a hollow form. It's not that I can't get to it...I just seem to ALWAYS get it thinner than the rest of the piece! Doesn't make sense. Oughta be thicker if anything. You would think that knowing I have a tendency to do this, I could overcome it! It's not so important on forms with an overall thickness of 1/4" or more, but on thinner ones, that thin spot affects the finish and as far as I'm concerned, it's ruined.
What's your trouble spot?
Re: What's your "trouble spot"?
Inside bottom of bowls
Chris Andrew
>The inside bottoms of bowls still give me problems. There are two problems. First, getting the appropriate curve to the bottom. I have a tendency to flatten it out too much. The second problem is getting that curve smooth...with no ridges. I'm getting better at it, but still produce too many that have to be sanded smooth.
I don't do many platters but have similiar problems with them. In the case of platters, it's difficult to get the surface perfectly flat without ridges.
Don Emmerling
>Hi Carole,
My trouble spot is the bottom of small boxes, as in fixing patches of tearout or tool marks in a very narrow area. Sometimes I chase them all the way through the side or bottom of piece. I have aerated a number of items.
Regards,
Don
Re: Everything inside the shop door
RussFairfield
Jim Shaver - Oakville, Ontario
>Hi Carole,
My trouble spots depend on what I am making, spindle turning I find to come easier to me that bowl turning for example.
I think for spindle turning my challenge is always the surface finish on end grain resulting from my tool cut is my challenge, I ususally leave a tools mark and find it hard to cut clean...either on a pull for push cut.
On a bowl cut I find my shape on the outside for a continous for curve is my challege, it's part of the "dance" I have yet to master...I think one thing I have learnt is the importance of drawing the form I want in advance of putting my tool to the wood.
Take care,
Jim
the space in between my ears
Mike Schwing from Md.
>THAT always gives me the most trouble. It always wants to hurry me, when I slow down, I mean really slow down, I have no trouble spots. I've been in a mellow, easy paced groove in the shop lately, because I've decided to concentrate on triathlon right now instead of turning, my turning pace has gone from high production to taking my time - and it really does get rid of my trouble spots.
Jim Pugh, Ohio
>I find that my "old eyes", your expression, don't see one or more sanding marks until I start putting finish on and then they just jump out.
>My trouble spot is finding the time to do projects. I just read where Binh Pho works 8 yours then plays with his kids and then works on turnings from 9 to midnight. I'm not worth a darn afte about 9:30 so I don't dare go in the shop, I would hurt myself.
Ed Karch
Carole Valentine
>LOL! Ed, maybe you need depth marks on the tool shaft?
George Van in WI
>Being new to hollow forms my trouble spot seems to be the lower bottom curve. I have a hard time measuring and I cannot step cut as easily on the lower profile. I guess I have to learn to be more cautious and slow down more.
Re: Inside bottom of bowls
Don Henthorn
>Chris, I made some home made scrapers a while back from 1 1/4" 02 steel. One is a roundnose sharpened to 30 degrees like Bill Grumbine suggests. I have found this scraper to be great for smoothing out those troublesome ridges on the inside of bowls. Just a thought.
Barry Turner
>My "trouble spot" always seems to be whatever I'm trying to do at the time. My last trouble spot was yesterday when I was hollowing an 11 inch sassafras bowl. The walls were very thick, well over an inch. Still when I started my cut at the rim (cutting from rim to bottom) I would get a vibration. Sharpening the bowl gouge (Crown PM 5/8" with Ellsworth grind) was some help. Anyway, I was able to finish the bowl successfully. Still, I didn't expect this much vibration with bowl walls over an inch in thickness. The bowl was tight in the chuck, was not cracked and my lathe is a Stubby 750 and leveled and properly set up. A friend of mine suggested that I take the walls down to final thickness incrementally, say an inch or so at a time. I plan to try this next time. Any other suggestions?
Carole Valentine
>I think your friend was correct. Take the first 1 1/2" starting at the egde down to final thickness and then move towards the center in increments. The mass reduces the vibration.
Carole Valentine
>Also, try a bowl steady or even steadying with your hand (I use a handful of shavings so it doesn't get uncomfortable)
Mike Rubes, Apex, NC
>Hi Carole,
Neat idea for a thread. The area I most consistently have troubles is getting the inside curve of a bowl to match the outside curve down where the sides become the bottom. I can usually get a decent curve on the outside and match it ok down for an inch or two, but as the transition from side to bottom happens, I just cannot seem to match it very well. Either too thick/thin/abrupt or whatever.
I know that practice is the key and fortunately I have lots of friends and family to give "practice" bowls to! And a wood burning fireplace!!! :)
Mike
Faceframing cabinets instead of turning in Apex, NC!!
Keith Tompkins
Keith Tompkins
>HI Jim, I may have the solution to your end grain problem.....as I'm sure you are aware, alway cut from largest diameter to smallest when spindle turning. It seems like a pull type cut would be cutting uphill, tearing grain in the process.
Here is a technique you can try...using a detail gouge, set the tool rest so the tip of the tool,(not the tool rest) is cutting right at the center line of the turning, and is pointed directly at the center of the piece. Now, rotate the tool so that the flute is at 90 degrees to the rest, ie, the tool is on its side. The bevel will be in contact with the turning.
To start the cut, touch the turning slightly with the very tip of the tool, until a small groove is created. Then, the tool will be able to follow the bevel into the cut. The flute faces away from the cut, no chance to dig in. The cut will be extremely clean, almost no sanding. With practice, you can cut coves, beads, and pommels this way. You will find you can cut straight into end grain cleanly, even form concave shapes in end grain with practice.
Feel free to email me if you'd like.
>Thanks Keith!
I do appreciate your comments...I will print this one out and give it a try!
Thanks..
Take care,
Jim
LOL! There are days I could say that!
Carole Valentine
Mine is......
Dave Peebles Lyons, Ohio!
>Hello Carole,
Mine is keeping up with all the messages and great work posted here lately. This place has really become... (The Place) for woodturning discussions.
I seem to read everything after most of you have hit the sack.
What I need is a chat at about 12:00 midnight.
Best wishes from,
Second Shift Dave :)
George Fitzpatrick - Springfield MA
>Depends on what I am trying to turn at the moment. Right now, my trouble spot seems to be common...matching the inside curve of a bowl to the outside curve. Getting better, and (surprise!!) find that the slower I go, the more successfull I am. I wonder though, with all the starting and stopping of the lathe so that I can take measurments, should I expect to shorten the lifespan of the lathe??
Chats
Carole Valentine
>Dave, where are you when we are in the chat room??? Take a break and join us. It's not just Wed night...we're in there a lot of nights. Last night there were 10 or 12 of us turners in there until the flatties took over for their scheduled chat. Probably be in there tonight as well (but not at midnight) It's a fun group.
>You can "sweeten" a platter with a ROS. Probably considered cheating by the purists here, but I made square cutting boards that I turned a slight depression into and also a bunch of stools. They both were about 14 inches across and about 3/8 or a 1/2" deep. The random orbital sander did a wonderful job of "fairing" them.
>A friend gave me some of that polyethylene (UHDPE???) sheet about a half inch thick. I have found all kinds of things to do with it. Lined the fence on the table saw. Made a cap or pusher for the live center to avoid marking things. I just tried holding a piece in my hand and rubbing the outside of the bowl to steady it. Much better and cooler that fingertips. Sort of a poor man's bowl steady. Time to get a real one with wheels and everything.
>Someone said the difference in a bowl made by Richard Raffin and one made by me is about four hours. In my case it might be six hours. If stopping the lathe to make measurements and to admire my progress in the last minute will shorten the life of a lathe, mine will die very young. I wonder how it lasted this long? If stopping and starting kills them, I should start saving for a new one.
