new ornament
new ornament
new ornament
>Here is a new ornament style that I've been working on. I did this by routing V gooves in the ornament using my fluting attachment I built. Then gluing Purple heart into the groves. The ornament body is Buckeye. The color should get more purple once it gets some sun. It's only been in the shop since cut so it's kinda brown and dull right now.
I tried very hard to make the center of the finial the same thicknes s as the top but apparently the light reflects off it differently and makes the top look thinner. Ideally your eye should flow right straight through the beads on a continuous line. It does on the bottom but not on the top. I also think the beads on the bottom should have been smaller. Both sets of beads look funny, I'm not sure why. I think it's because I put 2 instead of 3 or 1, odd numbers usually look better.
The 2 beads on the ball make it look like it's a box with a lid. I wish I had only done one bead. I wanted to add some sort of shape to the Purple heart football shapes.
Re: new ornament
ornament photo
>For those who are interested here's how I shot it. I used the light from my window as the main source. The reflection from the window was pretty harsh with a rectangular hot spot. I put a translucent panel between the window and the ornament. Then the left side was too dark so I put another panel close to the left side to bounce light back in.
The background was too light so I put one of those reflectors you use to keep sunlight off the dash our your car between the window and the background. It's still a little too light. I should have moved the background further away but it was already on the edge of the workbench.
The light from the window was north light with nothing but clouds so I knew it would be too blue. I reset the White Balance to the "cloudy day" setting. That worked great.
I set the F stop wide open at f5.6 because this piece didn't need any depth of field and the background I was using had slight wrinkles and dents. The limited depth of field helped hide these. My shutter speed was 1.3 seconds. I used a tripod and was too lazy to pull out my cable release so I just set the self timer.
Hope this helps someone shoot thier own work.
Re: new ornament
How do you...
Paul in Phoenix, AZ
>...stop the ornament from swinging. When I tried holding it still, it still move a little after I let go.
BTW, I shot some photos of my piece last weekend using the manual setting on my camera. I like the results alot better than when I used the aperature priority setting. Thanks for that tip.
Re: new ornament
Re: How do you...
>Paul You have to just barely touch the ornament to get it to slow down the pendulum. Then you just wait. At work it's a nighmare because we have air conditioning vents in the ceiling that never shut off. Fortunately I have electronic flash at work so I just wait until the ornament rotates where I want it and hit the shutter.
Re: new ornament
Re: new ornament
Mike from St. Clair Shores
>John,
You are being overly critical on yourself. For a first attempt on a new idea it looks great. I'm sure your next one will be better, but the quality of the turning, the finish and the photo are all great. Any chance you can show a photo of your fluting jig? Or where you got the plans?
Thanks,
Mike
Re: new ornament
fluting jig
>Mike I'm calling this a fluting jig but really it's more of carving with a router jig because I tried to make it fully adjustable so that I could change it around for new ideas that I have.
You can see the bottom slides in and out and can be tilted a little. The box riser in the middle can swivel and the top platform also slides to adust the depth of cut or the angle of the cut. You can reverse the top and screw on any jig that you want to make so that the router will cut just about any shape.
You'll notice also there is a riser under the router. I plan to make 2 more blocks for this. One has one finger and one has 2 fingers. This will allow me to follow just about any pattern or even trace the side of a vessel. I also decided today that these fingers need to have a micro depth adustment so I can set the depth from there as well and sliding the top plate.
Re: new ornament
Re: fluting jig
>Mike Here are some photos of doing the ornament. On the second photo I had already started to round over the square pieces of purple heart before I remembered that I needed a photo so ignore that part.
Re: new ornament
Re: new ornament
Niedling
>John - Nice ornament and thanks for sharing your techniques.
Re: new ornament
Re: new ornament
>There's more to come. This was just the first step in the techniques I have planned. As Keith and others have said, if your going to teach you have to stay ahead of the crowd. I thought up a new idea and made some sketches one day. It required buying a new planer, rebuilding and aligning my table say and buiding the fluting jig. Now I'm ready to work out the hard stuff. Actually cutting and building the parts needed for the project. I'll probably make a series of test pieces gradually getting more complicated as I go. This is what makes it fun, pushing the envelope. At least my envelope anyway.
Re: new ornament
Now that is Beautiful
Dick Parr
Re: new ornament
Re: fluting jig
Paul in Phoenix, AZ
>What type of router are you using?
Re: new ornament
Re: fluting jig
>Paul This is a Dewalt trim router. I plan to make another shorter box that will let me use my Porter Cable because it will take 1/2" router bits and I have a lot more of those.
Re: new ornament
Re: ornament photo
JKJ in East TN
>I enjoyed seeing the ornament itself up close last night in Knoxville. It is very well done and even looks better in person than in the photo (of course!). When I first saw it, I thought "how'd he do that?!" The contrasting elements create a dynamic design. The lighting and background in the photo are excellent as well.
I also liked the other ornament you brought - the one with the corners. I thought it really stood out in the sea of round ornaments! You should post a picture of it (if you haven't already done so and I missed it).
