Milwaukee/Sioux bearing update
Ed Moore
>I just ordered some bearings from ENCO that TD said would fit the subject drills and was pleasantly surprised to see that the price was $2.39 per bearing. They list for $3.50.
The part number is FP510-1961.
My question is: Has anyone successfully replaced the bearings and if so, how difficult was it to do?
Ed
Re: Milwaukee/Sioux bearing update
The other thread..
W.C. Turner
>from a couple of days ago, T.D. is supposed to be putting together a "How To" with text & pics.
Richard Allen
Richard Allen
>Basicly you cut the bad one of with a cutoff wheel in a drimel and then press the new one on using a socket or something that will contact just the inner race. It is a good idea to inspect the shaft and remove any burs... Also a little light lub is a good idea. Take your time and you will be done in 20 or 30 minutes.
Darryl Hansen
>put a piece of metal that will fit between the bearing and the armature on either side of the shaft. Lay the metal pieces over the open jaws of a vise and GENTLY GENTLY tap tap until the bearing slides off. I'm afraid of the shavings when using cut off wheels but it does work...
Not all that simple...
David
>I thought that positioning the trigger before putting the case back together was kind of tricky. I also may not have positioned the brushes correctly too. Drill currently not working--may take another attempt at re-assembly before I call in the service technician.
I have the photos
T Daniel
>David, I have a number of photos to send Garrett for a library. If you need them now I can email them to you.
TD
Re: I have the photos
Richard Kremsdorf
>If the pictures showing how to do the bearing repair have been posted, please indicate where. Or, if anyone has any please send them to me.
I have the replacement bearings but don't want to pop the drill open till I have as much info as I can get!
let me know what you need
TDaniel
>I have detailed photos of the entire process on the later style drills. I do not have any photos on the old style but the motor is the same.
TD
Jens Bingel
>Ed,
I have a Milwaukee right angle drill and the ENCO bearing you bought will not fit on my drill. Before you remove the old bearing measure the shaft and make sure that the diameter is a 1/4 inch. The shaft on my drill is only 3/16".
wait!! first check
KEN RIEDEL
>I just replaced the bearings on my souix. what I did not do was check the housing were the bearing ride. the bad bearing spun in the housing and ruined it . TIP: put old bearing assembly in a vise and tighten, this will break the outer race and it will fall away the same can be done with the inner race.
Re: wait!! first check
Bill Crommett
>Also, consider the disposable knock-offs from Big Lots----$30.00
Re: let me know what you need
Richard Kremsdorf
>Rear bearing replaced successfully. Thanks to the group for all your suggestions and pix(live and via archive).
I was unable to budge the bearing off so I ground it down until there was just a very thin piece of the inner race left on 2 sides. Grabbing it with a visegrip and rotating snapped it the rest of the way.
I couldn't figure out how to remove the front bearing but decided to leave it since it is working (for now).
Re: Milwaukee/Sioux Shafts
>Jens,
Does your model # end in a "1"? Heard of another who had this problem, and found out there at least 4 versions of that Milwaukee drill. My Sioux has a 1/4" shaft.
m
Bill Hale
>I had my bearings pressed on but now I can nor re assemble.
Is there a trick to getting the brushes back in place ?
Bill in Casa Grande, AZ.
Jens Bingel
>Mark,
we communicated early March on the WoW site. The serial number for my drill is 611B9 03340425 and the Cat. No. 0375-1. The bearing I need is 3/16"x.625"x.196", ENCO does not carry this size. If you know who carries this size (other than Milwaukee) I would appreciate a short reply.
Happy Turning,
Jens
Re: Milwaukee Bearings *LINK*
>Jens,
Looks like you'll have to contact Milwaukee for the parts you need. The link below will take you to the parts list and numbers for your drill. Best I could find.
Good Luck.
0375-1 Parts
Jens Bingel
>Thanks Mark for your efforts. Fortunately I am in no rush.
Jens
Juergen
>Check to see if the armature moved on the shaft. This will keep the bearings from locating properly.
