Re: You variable Speed guys... (A little long)
Gary Ratajczak
>I just did a little research myself on DC motors. (Anyone with more info - feel free to correct me on any errors).
The ones I found from Surplus City are typically open frame motors. They are commonly used by the guys with mini metal lathes, and mounted in a box in back of the lathe. The motors commonly used are from a treadmill, and rated at 2 to 2-1/2 hp. They are not a direct correlation. You would end up with somewhere between 1/2 to 1 actual hp in an AC motor. Any motors rated less will not have proper torque at the lower speeds. In order to run continuous, they MUST be fan cooled (again, problems with being open ported).
The motors I was able to find that would have been large enough hp, and totally enclosed, were to big to mount under the mini lathe. Also, keep in mind that you will need to make mounting brackets, and change pulleys.
Most motors are 90VDC. A speed controller with 110 VAC in and variable DC out is what is required. I found them surplus for $49.00 to $250.00, depending on source. One already in a box, with switches, heatsink and proper setup was $150.00.
If you have a Jet mini, they now offer an upgrade kit. It sells for about $150.00, plus shipping. You need to search a little. Direct from Jet is more $$. I have a link at home for one e-shop that has it for the $150 price. Provides motor, controller and all mounting.
So - to sum it up - after you buy a surplus motor, DC speed controller, heatsink, power resistors, control potentiometer, brackets, pulley and time, I think you will be right at the Jet upgrade kit. Hmmmm..... I bet they knew that when it was priced :-).
So - what have I done so far. Nothing but continue to change belts on my Jet Mini. I think I might just offer current unit for sale, and buy a new Jet VS model. Still seems like the easiest option in the long run.
I am going to keep looking for a motor and control. I had a few ideas for using one on a multi wheel grinder setup. I turn a lot of miniatures, and could use a very slow speed setup. DC motor would be a nice unit to have for that type of setup. I need to read up a little more on the torque requirements, and what DC motors are capable of.
